It is currently Mon Jun 23, 2025 9:22 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Apr 09, 2006 11:42 pm
:lol: :lol: :lol: nice one!
theres an electric car buzzing around ballarat, i love it! im not sure what the base car is, i think maybe it is a kit? i dont see it that often, i think perhaps maybe it is just a hobby car?
id definately be interested in the toyota prius...but i suppose soon we are going to see more hybrid cars on the market and they will become more availible.
but an electric mini would be rad. the key issue is battery life versus weight, placement, and of course cost. batteries are expensive themselves, but then you ahve to charche them?
perhpas a whole put-load of AA batteries?????
the caravan industry is really pushing the solar thing, to charge the batteries when you're not using them. they arent particularly effective, but perhaps it is a worthwhile addition? or would the spin of the wheels/motor charge them like an alternator/generator, so you never ahve to worry about it?
78 Leyland Mini - Prince
PostPosted: Mon Apr 10, 2006 1:04 am
the NiMH battery packs some electric cars are using ARE actually heaps and heaps of AA batteries all shrike wrapped and soldered together
PostPosted: Mon Apr 10, 2006 12:08 pm
that would be high-larious
PostPosted: Mon Apr 10, 2006 4:23 pm
Mate work for a big fleet company and they have a Toyota Prius that is just out of warranty and the batteries need replacing...........
You could almost buy a Toyota Echo for the price of the batteries. :shock:
PostPosted: Wed May 03, 2006 7:31 pm
Daffodil 1275
i would stick with optima yellow tops
51R- 12kg
- 41 amp/hrs
- 625 cranking amps
12x12= 144kg for a 144volt sys not that heavy, it would probably lack range though
or
D34- 19.5 kg
- 55 amp/hrs
- 870 cranking amps
12x19.5= 234kg for a 144volt sys, this would have more range
with a WarP "9" motor at 63kg plus your gear box, i think you could get the weight of the car down to about 100kg above a standard mini (about 800kg or so) with a zilla 1000k you would have a quick mini.
870amp x 144volts = 125280 watts or 125.3 kw with a motor which is about 85% efficient this means 106kw at the fly wheel and because electric motors have there power from nil rpm, this setup would rip your head off. i would mount a swift gearbox on a standard mini subframe and have a similar setup to this toyota echo conversion
http://www.electric-echo.com/
PostPosted: Wed Jul 08, 2015 5:21 pm
I have purchased it from australia.
Single Phase Electric Motors Australia
PostPosted: Wed Jul 08, 2015 6:52 pm
The a series with gearbox is around 150kgs wet according to some sources, so if you put in a 63kg motor plus a 25 kg gearbox then you can afford to put 62 kgs (plus a bit) of batteries without affecting weight.
And it would ruin any street mini in terms of straight line speed. Maybe with cornering too due to the low centre of gravity and weight distribution.
PostPosted: Wed Jul 08, 2015 6:55 pm
PostPosted: Wed Jul 08, 2015 10:23 pm
I feel like Sam Neil
PostPosted: Wed Jul 08, 2015 10:47 pm
There have been a few elec minis and mokes over the years, the nicest one is a moke that was built in Sydney a couple of years ago,
link here http://www.mokeforum.com.au/index.php/topic,7783.0.html
a few years ago there was a brown mini in this forum somewhere
PostPosted: Thu Jul 09, 2015 9:16 am
Canberra :?:
PostPosted: Thu Jul 09, 2015 10:04 am
9YaTaH wrote:
Canberra :?:
The signature of the poster is a link to buying electric motors, possibly spam post??
PostPosted: Thu Jul 09, 2015 5:39 pm
9YaTaH wrote:
Canberra :?:
Spambot.
Mod edit
PostPosted: Fri Jul 10, 2015 4:06 pm
cool, I reckon he's past his prime, but whatever floats your boat I guess.... I usually feel like Scarlett Johansson
PostPosted: Sat Jul 11, 2015 1:10 am
You mean soft but firm?
