It is currently Sat Jul 05, 2025 1:15 am
 Post subject: clutch backing plate
PostPosted: Sun Apr 09, 2006 9:00 pm
the motor is coming together nicely... next bit I have to tackle is the clutch backing plate - it's groovier than Kev was in 1972....
I want to get it machined, but is there anything I need to do with it at the same time, like machine the posts (the knobby bits that go through the flywheel) down?
I ought to get the flywheel machined at the same time, right?
PostPosted: Sun Apr 09, 2006 10:39 pm
Well generally whatever you take off the backplate needs to come off the 3 posts too whilst you are at it.
Otherwise, you are reducing the clamping load of the diaphragm.
Ideally the diaphragm spring should be FLAT when the backplate/clutch plate/straps/flywheel are torqued up, do a dummy build and take a peek under the diaphragm cover to check.
See http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
for Chichm's theory on it. Yes I believe he's right. :wink:
<edit> yes face the flywheel if it needs it before doing check above.
PostPosted: Mon Apr 10, 2006 1:08 am
thanks Kev - I read that article a little while ago, but forgot all about it, I'll have a fiddle
here's a query - what do you do about centering the backing plate? I've always just held them up and shoved the bolts in , but is there a right way - old SP #64 says to use some special tool, but I've no idea what that'd do :roll:
PostPosted: Mon Apr 10, 2006 7:16 am
I hold the backing plate up from behind while I get the top bolt in, leave loose. Then put the other 2 in, leave loose.
Then, I remove one at a time to put Loctite 262 on the threads, screw them all in evenly and torque up using calibrated left arm and ratchet.
Reason why I Loctite them- I had a screw work loose, once...... :wink:
PostPosted: Mon Apr 10, 2006 7:37 pm
i went through this. in the end i sent it to GR and he machined, lighten and balance the flywheel and backing plate for a very good price. i would give him a call.
PostPosted: Mon Apr 10, 2006 8:39 pm
yeah, that's all I do too... just thought there might have been a proper way
PostPosted: Wed Apr 12, 2006 4:21 pm
Does just putting the bolts in ensure that it is centered? I thought there would be some room for the backplate to wander even with all three bolts in, or is it simply compelled to line up?
I worried about this recently on my own engine, I just measured and used my eye till I was fairly happy.
PostPosted: Wed Apr 12, 2006 7:22 pm
Mick,
It IS centred, because the 3 sets of straps are all the exact same length. Unless the strap holes or the bolts are worn... :lol:
PostPosted: Thu Apr 13, 2006 9:18 am
Mick,
but what if the backing plate is off centre, even though the straps are the same length, can't it be a little bit up or down through the holes in the flywheel ?
I'm about to do dad's clutch, so I'll see ;)
PostPosted: Thu Apr 13, 2006 5:33 pm
Simon it is simple geometry- if the 3 holes in the backplate & flywheel are accurately positioned (they are, if not homemade) and the straps are all the same (better be, or you need new ones!), it will run true. :wink:
PostPosted: Fri Apr 14, 2006 1:01 am
I dunno Kev - simple geometry to someone who can't remember how a right angle triangle works is stretching what I can work out with a flywheel... but anyway, I put it together and it's too close to centre to tell if it's not properly centred.... I couldn't move it with a screwdriver... meh, I'm not going to question it ;)
the spring is nice and horizontal too - without me even doing any adjusting :)
