It is currently Sun Jun 22, 2025 12:44 pm
 Post subject: wat size is my carby?
PostPosted: Wed Apr 07, 2004 5:21 pm
hey guys just wanna know wat size it is, not sure if its standard or a different one but i took it off to measure the hole and it was inbetween 1.25" and 1.5" but closer to the 1.5" but not quite all the way there?
im after a ramflo type airfilter for it so wat size do i get? also does anyone have a spare they wanna sell me?
thanks guys.
PostPosted: Wed Apr 07, 2004 5:47 pm
Are the 2 mounting studs vertical (for 1.25") or at 45deg (for 1.5")?
PostPosted: Wed Apr 07, 2004 5:52 pm
you can tell by the size of the plunger cant you? :?
*a very uneducated opinion*
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet. :P -Tzi 4-9-04
PostPosted: Wed Apr 07, 2004 7:02 pm
The size of an SU carb- 1.25" (HS2), 1.5" (HS4), 1.75" (HS6) is measured where it bolts onto the manifold. Intake size is a little less. 8)
PostPosted: Thu Apr 08, 2004 10:10 pm
oh ok then, thanks heaps guys...
must be a 1.5" then cause,
a) bolts are on a 45 deg angle
b) if intake side is a little less then it must be 1.5" on exhaust side.
THANKS HEAPS TO ALL....
BTW, wat kind of ramflow filter thingy should i get?? If i go dwn to the local car auto shop wat do i ask for? im just after a cheap one cause there's no filter on it ATM.
PostPosted: Fri Apr 09, 2004 1:10 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
dont use ramflos dust and crap get past them two easy they never seal corectly use a ramtube with a sock or alike
makka
PostPosted: Fri Apr 09, 2004 10:52 am
what they normally go for?
has anyone got one for sale second hand or something??
the filter element...do u mean literally put a dirty smelly sock on it :oops:
or is there something called a sock that u can buy for it???
sorry but im kinda new to carby set ups.... :oops: :oops: :(
PostPosted: Fri Apr 09, 2004 11:04 am
i dont think makka literally means a dirty sock dude! :) you can buy a piece of filter foam thats made in a shape sorta like a sock, it just slips over the tube and usually you have to keep it on with a cable tie around the base
PostPosted: Fri Apr 09, 2004 2:13 pm
`Socks' are made by Unifilter, you can get them from Opposite Lock Accessories, or most 4WD or spares places have them or can get them in.
See this page, 1/2 way down, for pic of SU ones.. http://www.uniflow.com.au/sports.asp
Finer Filter used to make them too, but they got bought out by Unifilter, then closed.. :cry:
PostPosted: Fri Apr 09, 2004 6:23 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
k and n pan cake filters are also good and the one with a taper about the best expensive but you clean and reuse them same as the sock
makka
PostPosted: Fri Apr 09, 2004 7:10 pm
I LIKE my Lynx Ramflo with its Finer Filter element..with the Dellorto I got no freakin' room for socks, or a K & N.. :lol:
