It is currently Sun Jun 22, 2025 10:04 am
 Post subject: Hooking up fuel guage
PostPosted: Mon Mar 06, 2006 11:33 am
Guys I was wondering if anyone had solved this problem. I was told by the leccy who did the headlights etc, that he couldn't hook up the fuel guage of the Starlet to the fuel level sender of the Mini tank. Is this correct and if so is there any other after market solution? Could I simply remove the Mini guage from the pod and mount that?
Matt
PostPosted: Mon Mar 06, 2006 11:46 am
matt i just took the mini gauge out of the mini dash and used that, made a nice little surround for it and put it under my dash. Im not sure if its ment to have a regulator or something for it as mine reads over full when full and about 1/4 tank when empty.
1974 Moke - 998cc
PostPosted: Mon Mar 06, 2006 11:53 am
The fuel gauge is normally run of the voltage stabiliser and is only 10 volts that would be why your gauge reads wrong :D
PostPosted: Mon Mar 06, 2006 11:54 am
I'm looking at an autometer fuel guage and i need the OHM range to get one that reads correctly..anyone know it?
PostPosted: Mon Mar 06, 2006 12:11 pm
Thanks mate, thought there must be a reason for it, will see if i can run the stabiliser inline some how.
1974 Moke - 998cc
PostPosted: Mon Mar 06, 2006 12:33 pm
Would the OHM range be in the manual. I'll have a look tonight as this would be a good solution. Cheers for the info guys...I think I will go the standard mini item in the first instance.
PostPosted: Mon Mar 06, 2006 12:47 pm
It's all here:
http://www.ausmini.com/forums/viewtopic.php?t=14581
PostPosted: Mon Mar 06, 2006 4:37 pm
haha, I've never had a mini with an accurate fuel guage :) I just got used to carrying around a 5litre Jerry everywhere :wink:
(along with my 5 litres of oil.....or part thereof......and a couple of water) :roll:
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
