It is currently Wed Jun 25, 2025 12:01 pm
Post new topic Reply to topic  [ 1054 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 71  Next
PostPosted: Tue Feb 21, 2006 6:46 am
Hi Matt,
These tyres are unbelievable.
They have different compound rubber across the the tread face - harder in the centre and softer on the shoulders with 6 ply nylon sidewalls (very stiif but not tto stiff). The compounds have a high silica content so they are excellent in the wet. Really good stuff. The only thing comparable would be the A032's or Continentals from the UK or maybe Hoosiers from the 'States - all available in 13's.
But sorry Matt, Sp9000's dont come in 12's. :cry:
Dean - PM sent. Give Stuckey's from Melbourne a ring as they were the only guys willing to commit to the sale.
Like the spiel says "to fit...imported exotic and performance cars" - thats us!!!!! :wink:
Andrew
PostPosted: Tue Feb 21, 2006 7:19 am
are Yokohama AO32R illegal for road use in AU? they come in 13" wheel sizes as well (although choices are limited to 175/60R13 77H or P215/50R13 84V...i am guessing the latter would only be an option on 13x8's)...and look pretty funkay...
Bling me up Scotty!
PostPosted: Tue Feb 21, 2006 7:42 am
I have ran Ao32r's in 10inch and i thought they were the camels humps, awesome traction in the wet and dry. I will definetley use these again when my car is finished.
How come everyone uses 12 or 13 instead of 10s, is it down to traction or looks.
I will never change from 10s, i just love the way a mini handles on the wheel size it was designed to use.
Sorry if i'm goin off subject i'm not tryin to hyjack this thread.
kev
my swiftmini @ http://www.16vminiclub.com/forums/viewtopic.php?t=4888Image
PostPosted: Tue Feb 21, 2006 7:52 am
kev
A032R's are great if you have the $$$ to replace them as often as you will with a hybrid car..
We can't run 10's because we need big brakes by law ;)
PostPosted: Tue Feb 21, 2006 7:56 am
Yes i forgot.
1 wheelspin off the lights and back down the tyre fitters.
Bigger brakes is probably a good law.
thanks for answers.
PostPosted: Tue Feb 21, 2006 8:02 am
according to tirerack.com the yoko A032R's arent that much worse in terms of wear than the dunlops...the yokos rate 6.0 and the dunlops rate 7.1...but the yoko's crap all over the dunlops in the actual performance categories...you can also get the A032R's in a H (for hard) compound which according to yokohama makes it last longer than the same tire in the S (for soft) compound version...
the 'lops:
http://www.tirerack.com/tires/tires.jsp ... Sport+9000
and the yokos:
http://www.tirerack.com/tires/tires.jsp ... DVAN+A032R
Bling me up Scotty!
PostPosted: Sat Mar 25, 2006 11:25 am
Alrighty..havn't updated here for a while, but the frame is now 95% completed..
Here is a shot of the engine mounts tacked on, just need to weld them up and drop the engine in one last time to be sure, then i'll clean it up and get it powdercoated.
PostPosted: Sat Mar 25, 2006 11:47 am
Mini Mad wrote:
... drop the engine in one last time to be sure...
Hahahahaha sure :lol:
Keep up the good work. That will look great once powdercoated.
What colour?
PostPosted: Sat Mar 25, 2006 11:50 am
The TIG
I wish I had my subframe powder coated, I'll do it next time it's out. Please post pics of it when it's 'coated.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Sat Mar 25, 2006 11:52 am
Probably a charcoal grey colour...i'm going to do the wheels the same colour at the same time..
There is still alot to do!!!
PostPosted: Sat Mar 25, 2006 11:56 am
Good idea to get them done at the same time :idea:
1. cheaper in bulk
2. I got my mags coated 2 years before my subframe,
and they're a slightly different shade. Same colour, same company :?
It's not noticable once fitted to the car, but I'd get the lot done at once, including any little brackets etc.
PostPosted: Sat Mar 25, 2006 12:18 pm
Thanks for the tip..i might get the grill done while i'm at it.. :)
Still have to get all the parts i've ordered..guages..PWR water to air IC, fuel pump..
Driveshafts..
Brakes..
Wiring/Computer...
But the subframe and engine should be ready to bolt up soon.
I'm aiming for July to have it in..
PostPosted: Mon Mar 27, 2006 6:05 pm
lookin awsome
do you need too have any qaulifications to weld that together your self?
id never try that my self my welds are shite, it would fall apart down tha road
PostPosted: Mon Mar 27, 2006 8:27 pm
Very nice!!
Dan
PostPosted: Mon Mar 27, 2006 8:35 pm
Thats a good question... I assume just getting an engineer to check the welds is good enough? Did you weld yours Josh?
Speaking of which anyone got a MIG welder they want to sell??
