It is currently Tue Jun 24, 2025 1:54 am
PostPosted: Fri Feb 17, 2006 7:58 am
Does anyone know of a brands who sells a three cyl tacho they all seem to have setting for 4 6 8
57 Morris minor
88 Rover Mini
PostPosted: Fri Feb 17, 2006 8:44 am
found this looking in google:
http://theneonedge.zoovy.com/product/GS-709
And this:
http://www.sunpro.com/product_category.php?id=289
1974 Moke - 998cc
PostPosted: Fri Feb 17, 2006 9:05 am
Maybe you could get a motorbike one? Do bikes have tachos?
PostPosted: Fri Feb 17, 2006 12:29 pm
The TIG
There are a few tachs out there for 3cyl's. I also have a 3 cyl in my car. I'm using the inner workings of the tach that came in the car from which I got the engine and putting them inside a custom Lucas housing. This way I will have a matching guage that is also accurate. I'm doing the same thing with the speedo. It's a bit of work, but it will be cool when it's done.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Fri Feb 17, 2006 3:59 pm
cheers guys
one of the tachos on 13secmini's link will work on practically anythingm, the dash on the sirion doesnt have a tacho so im looking for a clamp on style
57 Morris minor
88 Rover Mini
PostPosted: Wed Feb 22, 2006 6:44 pm
hey mate you can use any after market tacho on a 3 cyl car. you just have to hook a resistor in line between the coil sense wire and the tacho. then switch the tacho to 6 cyl setting. ;)
lookin for another clubby
PostPosted: Thu Feb 23, 2006 7:29 am
does the resistor vary from car to car (ohms) :D :D :D
thanks for the tip the tacho i had in the dash isnt that old (its one of those ones that changes colour)
57 Morris minor
88 Rover Mini
PostPosted: Thu Feb 23, 2006 8:00 am
Most (modern) motorcycles have tacho's. The one on the YZF 750 SP I had went to 13,000!
