It is currently Sat Jul 05, 2025 1:17 pm
PostPosted: Wed Feb 15, 2006 7:35 pm
as title suggests, is that possible so the seat moves back further? if not how do all you tall mini owners cope?
PostPosted: Wed Feb 15, 2006 7:40 pm
im now 6'7" and i run on the "normal" seat rails, just i set them back as far as they go (the third hole)... although when im in the passenger side and am sitting upright passers by can see my knees about the window sill :oops: ... just ask Betty...
i would be keen to find out how to get the longer rails too 8)
PostPosted: Wed Feb 15, 2006 7:43 pm
so ur drivin 1 at 6 foot 7 no worries..im a little shorter than that..couple of inches so i should be ablt to aswell
PostPosted: Wed Feb 15, 2006 7:57 pm
:wink: how tall are you mate?
PostPosted: Wed Feb 15, 2006 8:09 pm
bout 6'3" or there abouts
PostPosted: Wed Feb 15, 2006 8:12 pm
ur a midget! :lol:
chowdesu on here is taller than i :? hes about 6'8" :shock: give it time... ill get there one day...
PostPosted: Wed Feb 15, 2006 8:18 pm
haha sound good..i want to buy a mini but the parents dont think ill fit even know dad used to drive 1 and hes alot taller than me
PostPosted: Wed Feb 15, 2006 8:25 pm
my parents had the same attitude at first :roll: but once they saw my sitting in one they knew i had enough room (....mind you this was when i was 15... and only 6'4")..
BUT, i am still interested in knowing how to get longer rails. would it just be a case of making new ones with the longer arms? would these then be too "flimsy"?
PostPosted: Thu Feb 16, 2006 1:37 am
The TIG
Either buy a set of these, or maybe make some that will allow you to move the seat even further back, this technology should be possible even at home.
http://www.minimania.com/web/Item/BG500 ... Detail.cfm
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Thu Feb 16, 2006 5:54 am
If you move the seat back further, i'm pretty sure you will have to 'modify' the storage compartment in the back....
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Thu Feb 16, 2006 6:30 am
Pretty sure these come up on ebay from time to time guy's so keep an eye out or get something similar made up .
PostPosted: Thu Feb 16, 2006 10:23 am
:? how so...?
PostPosted: Thu Feb 16, 2006 10:37 am
I've also wondered about this. I'm only 6'1 same with the old man we've adjusted the seat to the last notch which has helped. Only thing I have to change now is the steering wheel. It's like a bus wheel.
PostPosted: Thu Feb 16, 2006 11:10 am
I fitted a pair of MX-5 seats into a clubby,
using the longer mazda rails welded on top of the clubby "retaining bar"
Heaps of travel, plus tilt/reclining/lumbar adjustment 8)
Can post pics if anyone is interested...
PostPosted: Thu Feb 16, 2006 2:45 pm
sounds good mate
