It is currently Sun Jul 06, 2025 11:38 pm
 Post subject: Exhaust Heat
PostPosted: Wed Feb 15, 2006 9:02 am
Looking at getting new exhaust.
In the process i'm wondering what i can do to minimize the heat that comes through the floor form what I can only assume is the exhaust.
What options are there and what works.
I was thinking about that heat wrap stuff from the engine down to the cat but is there a heat sheild or anything that you can put between the exhaust and the floor that works?
Thanks
2008 Prado GXL
PostPosted: Wed Feb 15, 2006 9:22 am
Some factory systems (like the subie front exhaust section I have)
have a pressed half round heat shield ex aluminium to protect the floor & sensitive components.
PostPosted: Wed Feb 15, 2006 10:57 am
That was kind of what i was think about. Is there room between the exhaust pipe and the car?
I imagine to be effective they would have to be floating. I.e. a layer of air between the shield and the muffler and a layer of air between the shield and the car.
I was thinking about using that heat tape as an alternative but all it would take is the taped exhaust to catch on 1 speed hump and it would be very messy.
2008 Prado GXL
PostPosted: Wed Feb 15, 2006 11:02 am
I remember reading somewhere about heatproof insulating coatings for exhaust's , sort of a paint on type thermal blanket thet wouldn't tear on things like tape would . No idea where from though , maybe talk to an oven manufacturer or specialist engineering works that deals with heating fabrication .
PostPosted: Wed Feb 15, 2006 11:11 am
Ceramic coating works well but still $$$
And yes, those shields are fully floating but the gaps are in mm not cm
PostPosted: Wed Feb 15, 2006 11:13 am
ceramic paint?
PostPosted: Wed Feb 15, 2006 11:14 am
There was another one being touted as a spray on type thing , spray on thick and several coats so you ended up with a 3 or so mm thick blanket like coating . Not sure just how much heat it blocked but they were saying reassonable .
PostPosted: Thu Feb 16, 2006 3:53 pm
Sorry to hijack the thread but what kind of radiator has been used for the front mount?
PostPosted: Thu Feb 16, 2006 4:02 pm
custoooom, my friend..
PostPosted: Thu Feb 16, 2006 9:20 pm
Yes, his was custom made, but it only doesn't heat up 'coz he's got NO THERMOSTAT in that thing. I use an Alfa-Sud item on my LS. So long as you carefully fill it, and make sure it is full of water, ie. no air, it works a treat.
edit: oh, and long-tube headers make the floor hotter than usual, too. like mine. The 3>1 collector is just under your feet, it sure gets warm. :(
PostPosted: Fri Feb 17, 2006 9:57 am
I can actually feel warm air coming up the gearstick collar. Makes me wonder if i might have a small leak where it connects to the catalytic converter. :shock:
2008 Prado GXL
PostPosted: Fri Feb 17, 2006 11:54 am
Die Die Die!!
take off ur gator get some selleys and use that then put your gator back ontop :) problem solved :)
edit:to seal your gator that is...
PostPosted: Fri Feb 17, 2006 7:43 pm
Rover minis have a full length heat shield under the floor above the exhaust. Get one from Steve at Brickworx and you'll be sorted. If he hasn't got a good one you can buy the quilted alloy/fibreglass/alloy sandwich sheet and make one youreself. Don't wrap the exhaust in the fibreglass wrap if you plan to drive the car really hard. You will just deform/root your exhaust. I had my extractors wrapped in the fibreglass bandage. The insulation was so good you could touch the exhaust straight after a drive but the welds all failed and the pipe warped like it was made of play-doh.
PostPosted: Sat Feb 18, 2006 4:18 pm
lucky it didnt fall off :!: :oops:
