It is currently Thu Jul 17, 2025 10:31 pm
 Post subject: Su Carbs
PostPosted: Wed Feb 08, 2006 9:50 am
I have a feeling i may need to fix my carb... (it's only leaking fuel) so i figured i might go to a hif 1.5 inch considering how f250 drivers think i drive. :oops:
but..
Which carb is which?
I always get confused when the Hif44,hs6, etc is used to describe carbs...
can someone list the "other names" for the different sized carbs as per the float bowl position ( i'm not fussed about the left/right handed ones but it may be a useful reference)
can someone fill in the blanks...
1.25" = hs(whatever)
1.5" = hs(whatever)
1.5" (hif) = HIF(whatever)
1.75" = hs(whatever)
1.75" (hif) = HIF(whatever)
2.0" = hs(whatever)
 Post subject: Re: Su Carbs
PostPosted: Wed Feb 08, 2006 10:28 am
1.25" = hs2
1.5" = hs4
1.5" (hif) = HIF38
1.75" = hs6
1.75" (hif) = HIF44
2.0" = hs8
Pete
PostPosted: Wed Feb 08, 2006 10:40 am
1 plus the number of eighths of an inch. So HS2 = 1 inch plus two eighths of an inch, HS4 = 1 inch plus four eighths of an inch.
HIF38 = 38 milllimetres.
i.e. what he ^^^ said, but in an easy to remember format.
I believe...
PostPosted: Wed Feb 08, 2006 10:51 am
Ah.. perfect.. thanks..
PostPosted: Wed Feb 08, 2006 1:11 pm
also
1.75" (hif) = HIF6 (Turbo Version)
PostPosted: Wed Feb 08, 2006 1:13 pm
oh ya.. the pressurised bowl business.. :)
PostPosted: Wed Feb 08, 2006 7:59 pm
There was an HS7 too, I heard- 1-7/8"... :wink:
PostPosted: Wed Feb 08, 2006 11:45 pm
yeah i`ve heard that plenty of times but don`t believe i`ve actually ever seen one in the flesh
then there is all the earlier versions,,,just plain "H" series still with side float bowl but a big alloy bolt fits it to the body of the carb from underneath & they also had a funny little "gland seal" that was common leaker with old age & also the carb bodys were a bit longer.
just a bit of trivia for you all :-)
PostPosted: Thu Feb 09, 2006 5:54 am
Works cars in UK used to run H4s, as they bolted straight onto the early Cooper & S manifolds. Their bolt pattern was same as an HS2. :wink:
ps they missed one on that list- 2x HS1s were used on 948 Sprite I think. 1-1/8".
PostPosted: Thu Feb 09, 2006 7:05 am
Yeah , I've got a manifold for twin 1 1/8's that cost a 6 pack from someone who'd bought it for a mini and found they couldn't use it for twin 1 1/4" SU's , I was always going to find a couple of 1 1/8's and use it on an 850 for some fun (something different) but then found the sports850 and didn't bother . The studs look the same as in 1 1/4" (vertically opposed) but are way too close together for the 1 1/4" to fit , it's now on "the wall" in the shed as an oddity .
PostPosted: Mon Feb 13, 2006 5:14 am
HIF7s were fitted to the straight-6 Jags prior to injection. Excellent carb if you know what to do with it on a Mini (ask GR). Two issues with HIF carbs - the bi-metal strip controlling the jet height, and the float bowl capacity... KC.
Tuning should always be a compromise between what is possible and what is necessary.
www.calverst.com
PostPosted: Thu Feb 16, 2006 3:59 pm
Didnt the XK engines also use HD8's?
