It is currently Sun Jun 22, 2025 2:59 pm
PostPosted: Thu Feb 02, 2006 8:20 am
Rear mount came up very well and was much easier than whet i first thought
The alternator swapped from back to front , They must have used it this way on a different model because it lines up perfectly :) :) :)
Just have to sort out the clutch ,Im converting the cable to hydrolic and have an Exel pin on a hilux slave cyl get havent had time to make the bracket :(
57 Morris minor
88 Rover Mini
PostPosted: Thu Feb 02, 2006 8:29 am
Some good workmanship there. Don't you like it when it all just comes together without a drama.
Dan
PostPosted: Thu Feb 02, 2006 8:33 am
yes Everything has gone smoothly so far (knock on wood) :wink:
57 Morris minor
88 Rover Mini
PostPosted: Thu Feb 02, 2006 8:15 pm
Looking good, I dont suppose you could post a few pics of the whole subfame in its current state, ie all mounted could you. I am interested in this conversion for the Ute project :).
Chris
I can only please one person per day,
Today is not your day,
Tomorrow is not looking good either.
PostPosted: Fri Feb 03, 2006 7:18 am
Yes, the motor should be comming back out this weekend so i will get some good pics of the subframe then, ive got plenty of photo's the way it is i will get them all together :)
57 Morris minor
88 Rover Mini
Users browsing this forum: Bing [Bot] and 3 guests
