It is currently Wed Jun 25, 2025 12:42 am
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Tue Jan 31, 2006 9:09 pm
Guys,
Went down to the garage and decided to spin the turbo and see if i could reverse the turbo position. So now i have the following two options both with there own issues.
Please comment on your thoughts
OPTION 1
As per previous post
OPTION 2
I have decided to mount the radiator under the boot so it is now no longer an issue to try and squeeze it in.
The down side to each options are as follows(that i can think of at the moment):
OPTION 1
1. slightly longer log (100mm longer)
2. Very tight to run the exhaust behind the motor with the gearchange cables being in the way
OPTION 2
1. Part of the exhaust will be seen from the front of the car. The exhaust has to pass the bellhousing so you will see about 150mm long and 50mm hanging down (gutter cruncher).
2. Fresh air intake is currently facing into the engine bay and will possibly pick up hot air from the turbo.
Dan
PostPosted: Tue Jan 31, 2006 9:13 pm
Of the two options I would be going with option 2.
JC
PostPosted: Tue Jan 31, 2006 10:12 pm
Dan yeah I would go with option 2 aswell. As for being seen from the front you can well and truly see mine too as long as you don't go through the magic 100mm clearance from the ground it shouldn't be an issue. See pic...
Also did you get the measurements of the rad?
Matt
PostPosted: Wed Feb 01, 2006 4:51 am
option 2.... you could cover the exhaust with a sump guard.
my swiftmini @ http://www.16vminiclub.com/forums/viewtopic.php?t=4888Image
PostPosted: Wed Feb 01, 2006 4:54 am
can you run a phat air duct from under the inner wing to help with intake, also is the intake able to flip around 180 and point into the inner wing.
sorry if this is no help.....just throwing ideas
kev
PostPosted: Wed Feb 01, 2006 8:00 am
Matt,
Got rad sizes thanks alot. My exhaust will be much more noticable as it has to cross over the bellhousing so it will basicly be hanging below the beaver panel. I am now thinking maybe i de-bumper the front aswell and set up the No plate (like Chris, Twincammini) to cover over the pipe??
Kev,
Yeah thought about that to and I suppose the answer is that i will have to make up a sharper bend to achieve this, but should be able to make it work.
All comments are appreciated.
Dan
PostPosted: Wed Feb 01, 2006 8:28 am
minimetoy wrote:
Matt,
Kev,
Dan
whack a zeemax kit on it :) not only wont you see any engine componentry but it looks BLOODY AWESOME as well :) especially with the black border thing...gotta love that :) makes it easier to fit and repair after a bingle too :)
or if you dont wanna do that...why not stick another bend in the exhaust and make it run parallel to the log? then pull a 90 degree turn and go the path of the stock exhaust?
Bling me up Scotty!
PostPosted: Wed Feb 01, 2006 10:01 am
Wouldn't it suck if the extra length of the manifold and all the 90 deg. bends reduced the effeciency to the point you're no better off compared to running a ct9?
I'm not saying it will, but it will be interesting to see how much difference all the extra effort makes.
Keep going Dan, you'll make it all fit :D
PostPosted: Wed Feb 01, 2006 1:32 pm
i would doubt that you would lose that much efficiency...there will be more lag as the ct9 is a pretty quick spooling little turbo...but a GT25 is capable of so much more than a ct9 :)
Bling me up Scotty!
PostPosted: Wed Feb 01, 2006 1:38 pm
looks awesome btw dan...you reckon there'd be enuff room for a 6inch barrel liquid-air IC between the turbo output and the plennum?
Bling me up Scotty!
PostPosted: Wed Feb 01, 2006 2:11 pm
Inazuma,
Yeah, Ithink you could fit the barrel IC in without much of a drama.
I'm leaning to option 2 aswell....??????
Dan
PostPosted: Wed Feb 01, 2006 2:15 pm
minimetoy wrote:
Inazuma,
Dan
i'd say option 2 without a doubt...shorter header (less lag) easier to fit the dump pipe (PIA--)...an all-round neater solution IMO...and i dont think it is a compromise...its just better that way :P
Bling me up Scotty!
PostPosted: Wed Feb 01, 2006 6:51 pm
Dan, I hope like hell I can prove the doubters wrong and fit the ct9 up front. Becuase, f/me, it looks like you've suffered some mental strain trying to work this one out! Ah the sleepness nights.
PostPosted: Wed Feb 01, 2006 8:58 pm
Just keep moving foward is all i can say, don't look back.
Dan
PostPosted: Wed Feb 01, 2006 10:17 pm
Stripey, keep going, mate I had about a dozen of these situations along the way. You create a solution and they something else comes along and you have to change, redo etc. Trust me mate you'll work it out. :wink:
Matt
