It is currently Thu Jul 17, 2025 4:27 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Mon Dec 26, 2005 5:55 pm
just a progress report. head is back on and have set the idler gear clearance. so should be back on the road soon.
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Mon Jan 16, 2006 5:27 pm
i started the car up tonight. fire first go after i put the coil lead back on. was just checking if it had oil pressure. put in on and fired first go thats never happened before. i ran the cam in i am just doin front wheel bearings now.
PostPosted: Sat Jan 28, 2006 7:52 pm
more set backs the float in the weber was cracked so it was running like a bag of crap and flooding. i put a pulsar dizzy in too. but there is to much play in the timing gear so i am putting on new duplex sprockets and chain aswell. i have redone the floats aswell. does anyone no what the floats on the plastic type floats should be set at because i have found mix information.
PostPosted: Sat Jan 28, 2006 8:20 pm
According to my book-
15mm, full droop
7.5mm, fuel shut off- with lid held held vertical.
PostPosted: Sun Jan 29, 2006 2:05 pm
is that for the plastic type or for the round type
PostPosted: Sun Jan 29, 2006 6:15 pm
Dunno, that was from Des Hamill's book. Let me check another...
OK Stuart,
those settings I gave above were for Italian made Webers with brass floats.
The later Spanish ones with plastic floats use 12.0mm fuel shutoff height, and 26-27mm full droop. These dimensions are all with gasket in place.
:wink:
PostPosted: Tue Jan 31, 2006 12:26 pm
thanks mate thats what i have it set at
PostPosted: Mon Feb 06, 2006 10:42 pm
i have had it running for the last week or so now much better with a floats that works. much more power than before. i need to replace the timing gear though it's abit sloppy. i have all the parts i just have to get around to doin it. i put in a pulsar dizzy aswell with a bosch gt 40 coil. not the "r" type though can this cause problems. i have also noticed if held at 6000rpm in top gear for more than 15 seconds or so when i go to put the power down after backing off for maybe 2-5 seconds it seems hesitate and sounds like it's being over come by air and not getting fuel. could i be runnin out of fuel in the bowl. i am running 40 thou spark plug gaps if that helps
PostPosted: Tue Feb 07, 2006 5:52 am
Pulsar dizzy is DESIGNED to use a 1.5 ohm resistor type eg GT40-R coil. Yes it will work with a stock one, but will not fire big plug gaps as it should.
PostPosted: Tue Feb 07, 2006 5:19 pm
ok thanks mate i will upgrade when i have the funds
