It is currently Tue Jul 08, 2025 4:14 pm
 Post subject: Fuel Line Legality
PostPosted: Thu Jan 26, 2006 9:27 am
Hey Guys,
Just a quick One, Does anyone know if its ok to run EFI Lines inside the car or do they all have to be run underneath
Thanks,
Ash
PostPosted: Thu Jan 26, 2006 9:52 am
Ps, out of interest does anyone know where i can download the Second edition Australian Design Rules which relate to motor vehicle safety - I have the index of it but not tha actual rules
PostPosted: Thu Jan 26, 2006 11:44 am
hi,
dunno about the RTA laws, but i know that in competition (CAMS ect) fuel lines are run inside, but they have to be solid lines....
so long as you put a shild around them, i dont think there would be any problems with it....
hope that helps in some way
1978 British Leyland MINI Clubman S
1999 Hyundai Excel X3 rally car 3C PRC spec - VRC/VCRS Vic Rally
PostPosted: Thu Jan 26, 2006 9:06 pm
This what you after?
http://rvcs-prodweb.dot.gov.au/ADRS.html
Take your pick
PostPosted: Thu Jan 26, 2006 10:16 pm
I believe they can be run inside but need a physical barrier - plate etc. (e.g. where the moke fuel lines run inside the footwell to the firewall).
Not best practice though...
PostPosted: Fri Jan 27, 2006 6:07 pm
Yeah i dont realy want to run the lines through the car(brothers idea), but not sure if a 8m efi, and two 6mm return lines will fit in the std spot. Anyway if they do go inside there guna have to go around/over the seat xmember
PostPosted: Sat Jan 28, 2006 8:29 am
just run the 8mm down one side (under the shield) and the 2 6mm under the other side ( under the other shield)
lookin for another clubby
PostPosted: Sat Jan 28, 2006 9:20 am
a good idea but the battery cable still has to run somewhere (although i would rater put that indide than the fuel lines).....Im now thinking of putting a spacer between the floor and the original fuel bashplate to give a little extra room
PostPosted: Sat Jan 28, 2006 10:00 am
Why do you need to run two return lines? Most engine conversion people just use the factory mini line for the return line and runt he new (bigger) in parrallel
PostPosted: Sat Jan 28, 2006 12:54 pm
just run that inside then . problem solved.
Users browsing this forum: rocky&bullwinkle and 7 guests
