It is currently Sat Jun 21, 2025 2:18 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Apr 05, 2004 1:46 pm
Yep, `red850' on the MiniSpares board has done it. It's a +.040" overbore, stroked to 1400cc. Runs a Metro turbo setup. Not sure what the boost is, but hell, it lays rubber!
Good for 13s-14s on the 1/4 mile.
Was running 13" wheels but he couldn't get traction, now he has 6x10s with Yoko A008s.
BTW his gearbox is a rebuilt stock Mini-K... no straight cut sh!t.. 8)
that gives hope for my box...woohooooo!
[Maverick] 1971 Mini K
PostPosted: Tue Apr 06, 2004 9:08 am
yeah I was thinking the same!!! ill rebuild the metro box I have... what one do you plan to use?
PostPosted: Tue Apr 06, 2004 11:54 am
jesus christ that shits so cheap dr mini .. http://www.it-rite.com there in north rocks in syd... prety cheap too... 180 gig HDD $180
PostPosted: Fri Apr 16, 2004 1:47 pm
Windoz is crap, I'd never support Micro$ft... Run linux! (slackware :D)
PostPosted: Fri Apr 16, 2004 1:48 pm
Pfft.. Slackware
Gentoo is where the mark is :)
PostPosted: Sun Apr 18, 2004 9:51 pm
the mini k ive got sitting in the car at the moment........well i hope so unless someone has swapped engines :(
PostPosted: Sun Apr 18, 2004 10:46 pm
If you're going to run a turbo, rebuild the box- properly!
By that I mean- all new bearings from idler gear down to diff, new layshaft, check selector forks for wear/replace, check nose of mainshaft-( if worn go find another), new synchros, check synchro hubs for wear.
Check gears for chipped dog teeth.
2nd gear always cops the most abuse- I'd crack test it (dyechek) and the cluster gear to be sure.
BTW I've found some layshafts are better (harder) than others. I just replaced one in Baracade's 1380 that was 2 months old and was already worn so bad it had raised burrs on the shaft.
Dunno where it was made...or what from... that's half the trouble these days. :x
PostPosted: Mon Apr 19, 2004 6:02 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hey dr mini mg spares a guy who works the was telling me they make there own and are supoused to be the crap
makka
PostPosted: Mon Apr 19, 2004 6:57 am
The one I just fitted to Dean's car, we got from Greg at Mini Classic- it was locally made and looked the dog's dangles.. Dean's 1380 has got 110HP at the crank, we'll see how it lasts. The one we took out had no heat treatment marks at all, even on the ends.. :cry:
Wakefield Pk track day is on this coming Sat- we'll have at least 6 Minis on the track, including mine, James's 998 turbo, and a couple of 1380s- it should be fun! :P
PostPosted: Mon Apr 19, 2004 11:23 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
well i have to go to goulburn to have a look at a 850 for tracey apparently a original 1 owner car
so i may go to wakefield after
makka
PostPosted: Tue Apr 20, 2004 12:23 pm
dammit.......if i wasnt working id come down and watch :evil:
PostPosted: Tue Apr 20, 2004 4:14 pm
Action at Wakefield starts around 9.00-9.30, and we've usually had enuff fun by 2.00 pm.. so don't come too late! :lol:
PostPosted: Tue Apr 20, 2004 7:21 pm
There's a good chance I'll come up for a look! 8)
PostPosted: Wed Apr 21, 2004 10:52 pm
GO THE 1275 man,
i went for a spin in a 1310 with twin 1 1/4's, 1.75" exhaust,bit of a cam,then in a orked 1100,with twin 1.5 SU.monster cam,1.75" exhaust,and LOTS of head work,and the 1310 would almost double its performance :D
PostPosted: Thu Apr 22, 2004 7:05 am
Baracade's 1380 we dynoed at 110HP at Xmas (has 45 Weber, 286 cam) on GR's engine dyno- mine's got a little more mumbo, I think... if the 1380 gets there, we'll find out for sure. :twisted:
