It is currently Sun Jul 06, 2025 10:10 pm
 Post subject: Shortening HT leads?
PostPosted: Fri Jan 20, 2006 1:06 pm
Has anyone mucked around with cutting and shortening HT heads?
I want to have right angle plugs at each end, and have a few sets of spare leads, so I thought I might have a go. The way that they are stock (ie fibre core bared, folded over insulation and clamped by the steel plug) seems easy enough to replicate.
Is there a reason why I shouldn't cut them? Radio interference?, risk of shorting?
PostPosted: Fri Jan 20, 2006 3:03 pm
No problems doing it. You can even still buy leads in "kit" form where you cut them to length & put the distributor end contact on. (I've even used paperclips - they fit nicely)
edit <distributor, not coil> fixed
PostPosted: Fri Jan 20, 2006 3:21 pm
Cool
...to the pliers!
PostPosted: Fri Jan 20, 2006 3:43 pm
excellent, that'll sure tidy up the engine bay
http://www.minisport.com.au
the guys there are dead set champions
