It is currently Mon Jul 07, 2025 12:38 pm
PostPosted: Tue Jan 17, 2006 12:24 am
Hi guys,
Looking around for 1380 (73.5mm) pistons. Looking to build a high compression motor so want flattops if possible.
Are there any recommended products out there that you guys have used? If so, where did you get them and how much did they cost?
Cheers Ray.
1972 Mini Clubman 1380
previously 1330 85 bhp @ 6000 rpm new engine no idea?
My00 WRX
190 bhp @ 5800 rpm
PostPosted: Tue Jan 17, 2006 6:00 am
Many race guys use the 73.5 or 73.0 (1360) Hypatecs, if you can get them- but these days flat tops are old hat. You get more power with decent dished ones and decking lots off the 1275 head to unshroud the valves & get C/R up.. :P
PostPosted: Tue Jan 17, 2006 6:04 am
not sure if minisport have any 73.5s in dont see many around atm.. unless you bring in from O/S i got 1360s from minisport (hepatecs) good Price also hey Dr :wink:
PostPosted: Tue Jan 17, 2006 10:47 am
Take it to 1360, not 1380. 8)
Morphias. :)
_______________________________________________
If you're not living on the edge, you're taking up too much space...
PostPosted: Tue Jan 17, 2006 11:59 am
a wise move.. gives you a few more runs on the block before bin time :cry:
PostPosted: Tue Jan 17, 2006 1:47 pm
I got 73.00 mm Hyertecs and Hastings rings from Richardsons Engine Builders for much less than I was quoted from any of the Mini shops.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Tue Jan 17, 2006 2:21 pm
so what did you pay?
PostPosted: Thu Jan 19, 2006 12:23 pm
Just checked back on my receipts, seems .094 pistons were $163.50 and rings to match $72.00. From Richardsons Engine Service 08 8266 1646.
Slide
PostPosted: Thu Jan 19, 2006 12:25 pm
not to bad...
I paid 204.00 for my Hepatecs with Hastings rings.. :wink:
PostPosted: Sun Jan 22, 2006 7:16 am
Of course these 73.0mm pistons are available from your 'local' A-series specialist Graham Russell. Russell Engineering 61 296 302195... KC
Tuning should always be a compromise between what is possible and what is necessary.
www.calverst.com
PostPosted: Sun Jan 22, 2006 8:10 am
Yes they are.. But not as cheap as minisport atm :lol: :cry:
PostPosted: Sun Jan 22, 2006 9:08 am
Well, I decided to go the 73.5mm pistons anyway so Candy's going out to a 1380. Got Hypatec pistons with Hastings Rings as all have recommended here from Mini Craft. Set me back $286 for the lot. So not too bad at all.
Thanks for all the recommendations guys.
Cheers Ray.
My00 WRX
190 bhp @ 5800 rpm
