It is currently Sat Jul 05, 2025 12:36 pm
PostPosted: Mon Jan 16, 2006 3:35 pm
Hi does anyone know what needs to be done to covert from Super to Unleaded...any help would be great...
Thanks Monster Mini :D :) :D
PostPosted: Mon Jan 16, 2006 3:39 pm
You need to take the head off take it to a engine reconditioners and get them to fit hardened valve seats and possibly new exhaust valves. :wink:
Probably only needs hardened valve seats on the exhaust valves. :oops:
Oh and was there something about different valve guides :?:
Roads need more corners
PostPosted: Mon Jan 16, 2006 3:50 pm
Does anyone know the cost of this ......
Thanks Monster Mini
PostPosted: Mon Jan 16, 2006 3:57 pm
Can't remember the exact cost.. around $200 I think? But people reckon it's cheaper to keep using super with flash lube... I rather having the unleaded head.. it's much easier, you don't have to worry about additives
PostPosted: Mon Jan 16, 2006 4:48 pm
Yeah, im pretty sure its about the $200 mark.
Had mine done 8 months ago when engine was rebuilt.
No more Minis!......For now.
PostPosted: Mon Jan 16, 2006 4:50 pm
Slow-Po
Here some interesting reading for you on this very subject. :wink:
http://www.ausmini.com/forums/viewtopic.php?t=14225
http://www.ausmini.com/forums/viewtopic.php?t=13847
PostPosted: Mon Jan 16, 2006 6:07 pm
You supply the head....
$35 per seat FITTED
+ they will want to do a "service" on the head too.....wet blast, machine faces, lap valves and assemble = $120
Website: www.justanothermini.com
PostPosted: Tue Jan 17, 2006 7:52 pm
Yeah we got quoted 400 for the whole job. Thats shaved, and all relevant parts added to the head to run unleaded.
PostPosted: Tue Jan 17, 2006 8:53 pm
Just use flashlube Marlene. Works out to be about 2-3c per tank. Why do you want to convert? If you are going to do that, then might as well get the head reconditioned. In fact whack on a 1098 12G202 head instead for more oomph. (I have a spare one and so will many people...)
There is another option, an inline fuel catalyst for around $200.
Lillee - 1969 Morris Mini K
PostPosted: Wed Jan 18, 2006 11:55 am
next time you pull up to the pump instead of lifting the "super" you lift up the 98 ultimate/optimax etc etc
100% Pure A Series Turbo
PostPosted: Wed Jan 18, 2006 1:32 pm
It will limit the size of your exhaust valves if you convert to unleaded. If you want to get maximum performance out of your head then stick with super unleaded plus a dose of flashlube and fit the big valves (36 x 31 mm).
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Tue Jan 24, 2006 5:32 pm
I've got a fuelstar in my moke and I haven't had a problem- simple to fit- put it in between the fuel line from the pump to the carby. Took 5 mins. :D
http://www.aapsa.com.au/fuelstar.htm
MACK- '78 998 Leyland moke. Full Running Gear Rebuild Complete.
Apparently "Life's Short"- Have YOU done anything that took longer?
PostPosted: Tue Jan 24, 2006 6:02 pm
Mack,
I'd pull the head off it for a look after 12 months..
There was a test done in UK a while back, where they ran a stock 998 Mini flat out round a track for 500 miles, after doing a valve service and fitting a catalyst (can't remember what the brand was).
The deal was if any valve recession was evident after that, the owner would get a new head.
Guess who got a new head then... :shock: :x :lol:
<edit> Not saying NONE of these things work, but be careful there are shonks out there!
What do I do? Barney has Rover unleaded seats, and Ha-Ha runs Flashlube because his ex valves are too big for inserts... :lol:
Having seen what happens to a 1098 head in 6 months with NO additive, I know Flashlube works. I get less valve and seat wear now than I used to get with leaded fuel.
PostPosted: Thu Feb 02, 2006 6:28 pm
Fair enough! I'll definitely do that then. :(
Might end up fast-tracking the 1100 head I want for Mack if It all goes bad. Cheers for the heads up! :D
 Post subject: Petrol
PostPosted: Sat Feb 04, 2006 12:05 am
Is super the same as leaded fuel? is it worth the effort to change a mini onto unleaded?
