It is currently Mon Jun 23, 2025 2:12 pm
PostPosted: Mon Jan 16, 2006 2:44 pm
Hi guys, I'm new round these parts but this forum seems to be an excellent source of info for us Aussie transplanters. I am looking to do a very similar swap, but into a Morris 1100 not a Mini.
I was initally looking to do a 4age 20v swap, but if the whole front end of a starlet turbo can fit in there, struts and all, it may be easier than my other options.
Anyway, can one of you guys give me the track with of the Starlet?
PostPosted: Mon Jan 16, 2006 3:02 pm
no idea here...i am missing the passenger side driveshaft so am gonna get the driveshafts custom turned from billet to fit the mini...you might wanna do the same if the morris 1100 track is wider than the starlet gt's...or if its not then you could just get the donor's driveshafts modified to fit...
Bling me up Scotty!
PostPosted: Mon Jan 16, 2006 3:27 pm
Hope this helps:
Exterior
Length 152.201 in | 3865.9 mm.
Width 60.001 in | 1524 mm.
Height 54.301 in | 1379.2 mm.
Wheelbase 90.601 in | 2301.3 mm.
Front Track 50.801 in | 1290.3 mm.
Rear Track 50.201 in | 1275.1 mm.
More info here: http://www.conceptcarz.com/vehicle/z9657/Toyota_Starlet/default.aspx
PostPosted: Mon Jan 16, 2006 3:37 pm
1983 Toyota Starlet
Year 1983
Make Toyota
Model Starlet
Engine Location Front
Drive Type Rear Wheel
Price $5,150.00
Weight 1724 lbs | 782 kg
doesnt sound anything like the starlets we got down here :P
the engine is mounted nth/sth too...crazy starlet...spose thats why its at conceptcarz.com :P
Bling me up Scotty!
PostPosted: Mon Jan 16, 2006 8:28 pm
That'd be the KP series starlets....earlier than the FWD EP series......
apparently they're quite a fun little car.......with a 4age in them......the yanks drift em...
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Tue Jan 17, 2006 8:45 am
hmmm...wonder if it'd fit in a mini? :D
Bling me up Scotty!
