It is currently Sun Jun 22, 2025 9:10 am
PostPosted: Sun Jan 08, 2006 1:14 pm
Thank you so much for your help Chris!!! It's all installed and working perfectly.....
PostPosted: Sun Jan 08, 2006 5:30 pm
I have that cable as a back up. I mainly use my Denison Ice Link plus
That way I can control the Ipod from my steering wheel. and it charges the IPOD
PostPosted: Sun Jan 08, 2006 8:24 pm
I would like to have that sometime in the future Brett, but I don't have the multi function steering wheel.
Hey Chris, What do you do about charging your ipod while driving?....soon as I plug mine in the stereo drops it and reverts back to cd or radio.
PostPosted: Tue Jan 10, 2006 10:07 am
Tricky
Opps, had the same issue - something to do with different floating earths. There was a modification to the cable to include little isolation transformers.
Chris
PostPosted: Thu Jan 12, 2006 8:08 pm
Is that what I've been reading about on mini2? A Ground Loop Isolator?....I asked about it at Dick Smith...they didn't have a clue....only place I can find it is at radioshack in the states. :(
Hope it lasts to Bairnsdale and back on the weekend
PostPosted: Fri Jan 13, 2006 12:56 pm
Any ideas where I could find instructions on how to incorporate these "transformers" into my exsisting cable?
PostPosted: Fri Jan 13, 2006 5:10 pm
Tricky
I'll see if I can find out :)
Chris
PostPosted: Fri Jan 13, 2006 5:58 pm
Tricky
My source says Jaycar, he thinks the part number is MM2534.
Chris
PostPosted: Fri Jan 13, 2006 6:58 pm
XMINIX wrote:
Tricky
Chris
what are you doing in here Chris? :?
You should be out driving your new car :lol:
PostPosted: Fri Jan 13, 2006 9:19 pm
Hi Mike
Thanks just got back :) I ducked in before to check M2, ausmini and NAM - it's an obsession :)
Chris
PostPosted: Fri Feb 10, 2006 10:29 pm
Thanks for your help Chris...Got it all working and charging after buying myself a ground loop isolator...works a treat!!
PostPosted: Sat Feb 11, 2006 6:59 am
No probs. Hey if you are ever looking to go for a spin with other new MINIs, the clubMINI guys have a monthly drive (apologies if you already are aware of clubMINI).
