It is currently Sat Jul 05, 2025 5:59 pm
PostPosted: Fri Jan 06, 2006 4:36 pm
G'day all,
It's hot and I've got brainfade.
Have just fitted the D4R83 to my Minor.
I want to take the distributor drive out and rotate it by one tooth clockwise to give me better clearance between the oil pressure warning sender and the vacum advance unit.
Assuming I get everything lined up timing wise, am I right in believing that there will be no problem with the standard timing marks lining up when No. 1 is firing?
I need to use a timing gun to get it set correctly, so I need the timing marks to line up.
That's right - isn't it?
PostPosted: Fri Jan 06, 2006 8:18 pm
no problem your standard marks will still work.
PostPosted: Fri Jan 06, 2006 10:53 pm
Cool, thanks again.
PostPosted: Mon Jan 09, 2006 2:01 pm
Equally stupid question. Why use a Pulsar dizzy as opposed to the standard A+ dizzy?
2008 Prado GXL
PostPosted: Mon Jan 09, 2006 2:08 pm
A+ dizzy uses a different drive dog.
The pulsar distributor is more accurate
Electronic ignition lets you fire bigger plug gaps and gives a better spark
Pulsar dizzy isn't lucas :P
No points
the pulsar conversion is probably as easy as converting an A+ dizzy
Pulsar dizzy is probably cheaper than what you'd get a A or A+ dizzy for
my 2c
Roads need more corners
