It is currently Sun Jul 06, 2025 6:23 am
 Post subject: Steering Column
PostPosted: Wed Dec 28, 2005 6:41 pm
Hi all,
Just wondering if anyone has make there steering column adjustable, as the new Dash i just built/made i need the column to be about 30-50mm lower then what it currently is as i cannot see the gauges, i have worked out that i can put it on its spline thing and it goes lower by itself but not sure if this is any good for the column or rack. If possible i would like to tilt it near the top so as its simular to a newer cars column, if its possible please let me no how...
Rikki
PostPosted: Wed Dec 28, 2005 6:48 pm
Undo the brakets holding the rack in then twist it around to where you want it then retighten the brackets. Easy.
Pete
PostPosted: Wed Dec 28, 2005 6:56 pm
You need a steering column lowering bracket, which allows adjustment- and adjust it after loosening rack clamp bolts as he said ^^^.
This bracket bolts into the existing one under lower dash rail.
PostPosted: Wed Dec 28, 2005 7:07 pm
so i actually have to adjust the rack and cannot just adjust the column, also if i adjust the rack the hole in the floor wont line up, right???, doyou have any pictures of the steering rack and the bolts you's are talking about.
PostPosted: Wed Dec 28, 2005 7:12 pm
Sorry no have pics.
Lift the floor mat/carpet, there are 4 nuts sticking up thru floor, 2 each side. These are the rack U-bolts.
Loosen them, and the steering rack will rotate as you tilt the column.
Here is the bracket you need-
After adjustment, tighten the 4 nuts on floor.
PostPosted: Wed Dec 28, 2005 7:15 pm
Oh thanks Doc, i thought it would be harder then that, so ill do that, also do you know where i could get the bracket from in brissie?? or are they very hard to make??
Rikki
 Post subject: column lengths
PostPosted: Wed Dec 28, 2005 11:34 pm
I just fitted a longer Column to my clubby, there are 2 lengths so see if you can get the shorter one.
You could also change the boss/steering wheel as well
PostPosted: Thu Dec 29, 2005 5:27 am
yep do as above otherwise in around 6 months time you will have to pull the rack out and service it or get a new one. Lowering the Steering Column is a easy job refitting the Rack is not :wink:
Do a bit of phoning around for the bracket at the normal places (checkout How to Section) or otherwise UK Ebay always has them
PostPosted: Thu Dec 29, 2005 6:24 am
Any Mini shop worthy of the name will have these lowering brackets.
Try Matt Read.. :wink:
PostPosted: Thu Dec 29, 2005 6:07 pm
Cheers guys thanks for your i know i can always count on all u's
PostPosted: Mon Jan 02, 2006 5:33 pm
http://cgi.ebay.com.au/Mini-Steering-Co ... dZViewItem
PostPosted: Mon Jan 02, 2006 6:09 pm
skssgn wrote:
http://cgi.ebay.com.au/Mini-Steering-Column-Lowering-Drop-Bracket-NEW_W0QQitemZ4601463355QQcategoryZ32072QQrdZ1QQcmdZViewItem
Harhar, typical eBay..
New they are only 10 Bux at Kc... :lol:
PostPosted: Wed Jan 04, 2006 8:16 pm
Hii I just bought one from Carcraft only $10.05,
cheers Monster Mini
Users browsing this forum: No registered users and 26 guests
