It is currently Mon Jun 23, 2025 11:03 pm
 Post subject: Ipod in Mini's
PostPosted: Mon Dec 26, 2005 9:00 am
Just wondered if anyone has had any experience with ipod's in Binis? I have read about the BMW install and the Icelink...both seem to rate well.......
 Post subject: Re: Ipod in Mini's
PostPosted: Mon Dec 26, 2005 11:25 am
Tricky
I have one of the 'homemade' iPod connections on my Cooper. Some of the more expensive options require MFSW, which the Cooper does not have. I have basic connection, but it works :D :D :D
Try this link for making a 'homemade' cable: http://www.neeshil.com/nsite/miniaux.asp
Good Luck
Chris
PostPosted: Wed Dec 28, 2005 9:30 pm
Sorry Chris.....but whats MFSW?? :)
PostPosted: Wed Dec 28, 2005 9:39 pm
Multi Function Steering Wheel
leather wheel + Cruise + Stereo controls
PostPosted: Thu Dec 29, 2005 1:46 pm
Also..
Mother F**ker Stopped Working
PostPosted: Thu Dec 29, 2005 2:03 pm
Ahhhhh Of course :)
haha @ cush..... thats what I'm worried about!!
Are you sure this home made joby will work with an 2002?....I keep reading about 2002 head unit differences....Rang Mini.....got vague answers.
PostPosted: Thu Dec 29, 2005 2:22 pm
I may be wrong but I think the only option you have with a 2002 is to either use the iTrip or something similar. Alternatively you need to change your head unit as the 2002 has no aux input.
I use the belkin adapter with built in amplifier plugged into the aux input, sound quality is sooo much better than iTrip but if you can get a frequency without any interference the iTrip will work quite well.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Thu Dec 29, 2005 5:16 pm
For early 2002 models, you will need to check the production date of the head unit.
How:
Turn on Stereo.
Press M button within 5 seconds and keep pressing.
When you can see SN on the display, press + button.
the display will show software version like "SV 32-03 50"
this example means 32nd week of year 2003 software version 50.
If the unit does not display 50 then you are out of luck, and cannot use the DIY cable.
Chris
PostPosted: Fri Dec 30, 2005 6:17 am
Thanks Chris!!! Printing page as I type.....will give it a whirl....Have an electrical whizz other half so he should be able to rig me up the lead if this works.
Babes I have considered the iTrip...but only as a last resort...
Does anyone have the Dension Icelink installed here or is that just an American thing?
PostPosted: Fri Dec 30, 2005 8:32 am
Hmmmm.. problem
Mine doesn't have a plus + button :(
PostPosted: Fri Dec 30, 2005 1:38 pm
I have an iTrip, and to be honest, I would give it a miss. In Melbourne, there's too much crap on the FM band - I could never find a usable station. I ended up putting AUX INPUTs in the MINI and in my BA. However, if you are after a cheap one, used once or twice, PM me. :lol: :lol: :lol:
PostPosted: Fri Dec 30, 2005 1:50 pm
Tricky wrote:
Hmmmm.. problem
The '+' button appears as a soft button.
When you press the M button after turning on the radio, keep pressing/holding and SN 123456 will appear. At that point, you will note that the two soft buttons on the RHS which have '-' etched on them will have '-' and '+' in the LCD above them, press the RHS side on and it will cycle to SV 37-03 50 (well mine did anyway).
Good Luck, any probs let me know and I will walk you through it.
Chris
PostPosted: Sat Dec 31, 2005 9:03 am
Will give it another try Chris:) Will take your word for it about the iTrip...I havent heard anything good from anyone who owns one.....I have definitly now ruled it out.
PostPosted: Sat Dec 31, 2005 9:14 am
YAY!!!!! It worked
came up
SV 27-02 50
Is that good...Can I have the aux homemade lead thing?
PostPosted: Sat Dec 31, 2005 3:24 pm
Tricky
Yes, I believe that you should be able to use the homemade cable.
Good Luck
Chris
