It is currently Tue Jul 08, 2025 4:07 pm
PostPosted: Fri Dec 23, 2005 8:46 am
Hi all,
Which extractors would be best for a currently stock 1275 A+ motor?
There seems to be a lot of choice out there.
Standard advice is to get a RC40 exhaust but not sure which extractors to get. Do they all work? Do some work in different rev ranges? :roll:
Help please.
PostPosted: Fri Dec 23, 2005 9:50 am
Is it LCB 3 to 1?
PostPosted: Fri Dec 23, 2005 9:59 am
Since you are in Melbourne I have heard that the Link Automotive LCB are a good bit of kit, anyone got them and tried them I hear some Pom has copied them and claims they are his design :D
Jon
PostPosted: Fri Dec 23, 2005 11:33 am
yeah LCB (long centre branch) is what you want
maniflow or something..
i don't recommend lynx, as they don't fit properly.
PostPosted: Fri Dec 23, 2005 1:13 pm
For a road car with 1098 or 1275 upwards I reckon the Maniflow medium bore LCB is best. And they fit well.
But make sure it's genuine- there are Chinese crap copies about now. :x
PostPosted: Fri Dec 23, 2005 1:21 pm
:D never heard of lynx making extractors only inlet manifolds, there ya go you learn something new everyday :D
PostPosted: Fri Dec 23, 2005 1:28 pm
Do I need to do anything different due to SPi. i.e. does it have an exhaust gas sensor that needs to be welded in or anything. (I'm too lazy to go & stick my head under the bonnet, that and I'm at work).
PostPosted: Fri Dec 23, 2005 4:48 pm
whoops, i meant wildcat 8)
PostPosted: Fri Dec 23, 2005 6:19 pm
Slow-Po
Easy mistake to make, they look the same to me! :wink: :lol: :lol:
PostPosted: Fri Jan 06, 2006 1:50 pm
Jon
Yeap a lot better then the 3in1 big bore that i had. Better tourque and sound is great.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
Last edited by 1380 yellow devil on Sat Jan 07, 2006 3:33 pm, edited 1 time in total.
PostPosted: Fri Jan 06, 2006 2:27 pm
A SPi motor needs the oxygen sensor in the exhaust. Minimania sell LCB extractors with these fitted but you can convert standard using the an M18x1.5 nut (check, its the same thread as many spark plugs). The sensor is quite big and could restrict flow, even if you position it at the Y in the pipe.
It is illegal for you to remove the cat converter if you have a post 1986 mini BTW.
The standard cast manifold and twin down pipe arrangement in the SPi cars is not too bad. See photo. The sensor is in a pocket in the casting so it doesn't restrict flow.
M
PostPosted: Fri Jan 06, 2006 9:37 pm
I have some Perry extractors running on mine.
Thats all I really know about them.
Helps me get my 44+ bhp :)
No more Minis!......For now.
