It is currently Wed Jul 02, 2025 1:56 pm
 Post subject: after some advice
PostPosted: Sun Dec 04, 2005 8:39 pm
I have a standard 850 dont want to change the motor but was after a little bit more guts for the old girl would a set of 1.5 roller rockers and a set of extractors with the standard carb run alright I am already going to put on elecronic ignition as the motor has only done 20k km since being rebuilt. Long term i am looking at a jap engine transplant but want a little more for the mean time. all advice welcomed :?:
PostPosted: Sun Dec 04, 2005 9:37 pm
As a set of 1.5 roller rockers costs $BIG, and the stock 850 cam is pretty tame, I would change the cam first- then port the head or fit an 1100 one (12G202).
I doubt fitting a $500 set of rockers alone with stock will make more than a couple of HP (maybe).
You can do a cam change on an 850-998-1098 whilst engine is in car. :wink:
PostPosted: Mon Dec 05, 2005 9:41 am
Change cam, bolt on a bigger head as suggested. Whack on some extractors, RC40 exhaust and twin 1 1/4 SU's and you'll have a pokey 850 :wink:
PostPosted: Mon Dec 05, 2005 8:26 pm
I`d just leave it the way it is ,,,putter around in the thing & save yourself some money, spend that saved money somewhere usefull & constructive instead
PostPosted: Tue Dec 06, 2005 4:23 pm
like on a jap import engine swap theminiman just fix the body for now and save the big dollars for the engine swap
:roll:
PostPosted: Wed Dec 07, 2005 12:26 pm
what can i do as far as dizzy is concerned should i get a pulsar one if so which one for a stock 850
PostPosted: Wed Dec 07, 2005 12:49 pm
Read this How To:
http://forums.ausmini.com/viewtopic.php?t=12376
:wink:
PostPosted: Mon Dec 19, 2005 11:33 am
Whack on this, bolt on that, yada yada.
Mate, cheapest way out is to change your engine, pref a 1275.
Keep it simple.
PostPosted: Mon Dec 19, 2005 1:22 pm
Keep it simple.
What and also buy disc brakes for $2000 as well so that you can register the thing? Not cheap, not simple! :shock:
PostPosted: Mon Dec 19, 2005 3:35 pm
Keep it simple.
Depends on what state chong :lol:
PostPosted: Mon Dec 19, 2005 3:37 pm
IMO change the cam for something else like a stock 1100 or RE13 and the head to a 12G202 off an 1100. :wink: 1100(12G202) heads are really cheap.
Also to get the best out of the head and cam upgrade your carb to a bigger one and get some extractors.
It does sort of follow on from it'self doesn't it :roll: still it would be cheaper than getting a 1275 and disk brakes.
Roads need more corners
