It is currently Thu Jul 03, 2025 4:28 pm
 Post subject: Firewall Delima!
PostPosted: Sun Dec 18, 2005 6:10 pm
I looked at a car which is unregistered and has twin SU's yet the owner cut a oval hole (approx 150 by 70) to fit them. The owner just left it like that and i was wondering has anyone had experience modifying the firewall so as to build a "shell" around the SU's and hence retain the firewalls purpose and how hard is it to get an engineers certificate for this??
Thanks
Craig
Hi-Ho Silver LS1275
PostPosted: Sun Dec 18, 2005 6:40 pm
Many people in the past just welded or rivetted a box in there. This includes some wellknown Mini workshops here...
Mine has a big hole there too, I'm just going to bolt some alloy sheet to it, then belt the F#$% out of it to clear my Dellorto's Ramflo filter..:)
PostPosted: Sun Dec 18, 2005 6:56 pm
you can buy the boxes made.. or just make/get one made..
they are on www.avonbar.co.uk
PostPosted: Sun Dec 18, 2005 7:19 pm
Make up a template / highly illustrated diagram and take it to a local sheet metal place or to someone that can weld.
They wont charge much and you'll have it to YOUR specifications. 8)
PostPosted: Mon Dec 19, 2005 11:11 am
Hehe, sounds really bling there doc... :wink:
PostPosted: Mon Dec 19, 2005 2:34 pm
Hey, I'll nickel plate it BLING when I'm done with bashing it.:)
PostPosted: Mon Dec 19, 2005 3:05 pm
I can see you are going to be bust plating lots of things soon Kev :lol:
PostPosted: Tue Dec 20, 2005 7:27 am
thanks for all the help guys!
Does this work require an engineers cert because the cars unregistered????
Hi-Ho Silver LS1275
PostPosted: Tue Dec 20, 2005 8:06 am
technically yes, any work done to a firewall should be engineered. As a round nose has a hole in it already it wouldn't be too much of an issue. Some will say, why bother, but i will be the stick in the mad and tell you that technically you should as it's the law.....
Aaron
PostPosted: Tue Dec 20, 2005 9:05 am
Aaron
Thats good advise Arron :lol:
PostPosted: Tue Dec 20, 2005 12:42 pm
It's easy to make up a box out of alloy or you can fit a Mini battery box which is heavier but just about the exact size. I've used both in the past, as well as fitting and hammering a flat piece of alloy to clear the Weber. If you are using a long branch inlet manifold, which reputedly gives more power, then you really have no choice but to fit a box. You can get away without one and using the hammer if you're running a short branch (Warneford) inlet mainold - just. Of course if you have a swan neck inlet manifold (Lynx, etc) then you don't need to do anything, but these are frightfully inefficient and loose power on the Weber.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Tue Dec 20, 2005 1:53 pm
its only fire...... just buy a fire extinguisher :D
