It is currently Sun Jul 06, 2025 1:04 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Wed Dec 07, 2005 2:06 am
I know there was someone here installing a supercharger on the front of the engine here? Are you out there????
Just wanted to see your set-up
PostPosted: Wed Dec 07, 2005 3:38 am
For sale here...
http://www.ausmini.com/forums/viewtopic.php?t=13720
Also i believe SC850 used to use this method before going to the kit..
PostPosted: Wed Dec 07, 2005 5:54 am
That setup does look tempting, for a Clubby body. Doubt it would fit in a roundnose...?
PostPosted: Wed Dec 07, 2005 7:40 am
Getting ideas for the van eh :P
PostPosted: Wed Dec 07, 2005 8:07 am
I can't see if it's a round or clubby. I'll have to PM him.
Thanks!
PostPosted: Wed Dec 07, 2005 8:30 am
Clubby I think the bonnet latch is wrong for a round nose and it has a charcoal canister and dual circuit brakes both of AFAIK didn't come out on round noses. There is too much room in front of the engine as well IMO
Roads need more corners
PostPosted: Wed Dec 07, 2005 8:44 am
i have a few pics of a similar setup in a roundy :arrow:
PostPosted: Wed Dec 07, 2005 8:56 am
that... is a weenie little supercharger.. :)
PostPosted: Wed Dec 07, 2005 7:53 pm
There we go! Looks like it may be a real tight squeeze with a SC12 up front. Have to give it a test fit.
Ben- Is that one of those little electric powered superchargers? Looks like a vacuum cleaner motor :lol:
PostPosted: Wed Dec 07, 2005 8:25 pm
i have no information on the pics i cant remember where i found them sorry, but it is a proper supercharger that is belt driven
PostPosted: Thu Dec 08, 2005 8:37 am
i can trial fit mine on my mates car i think it will be a bit tight around the air filter. the inlet pipe could be made ok ,just would not be intercooled
PostPosted: Thu Dec 08, 2005 5:16 pm
Is there any limitations On what sort of SC you can Run at all If a A series Engine is setup for high PSI?
PostPosted: Thu Dec 08, 2005 5:21 pm
14 PSI is pushing it for the SC12, I think. The SC14, which is off the 1GGZE (I think), will go a bit higher, as it is a bigger s/c.
PostPosted: Thu Dec 08, 2005 5:24 pm
Depends on the type of supercharger
The SC12 / SC14 as fitted to Toyotas and the Lissholm type as fitted to Mercs etc have polymer coated rotors which start to melt at about 16 PSI
PostPosted: Thu Dec 08, 2005 6:07 pm
what about a EATON or Holden v8 TYPE?
