It is currently Wed Jun 25, 2025 12:33 am
 Post subject: 4E-FTE subframe
PostPosted: Sun Nov 20, 2005 11:45 am
does anyone fabricate these? i want one that will accomodate a flip-front...or do i have to make it up myself? either way does anyone have any resources/plans on how to make these?
i have heard it is possible to fit the starlet gt (turbo) engine in a roundnose...and this is what i am going for...i imagine i'll need to have a bonnet scoop...but other than this...it should fit right?
Bling me up Scotty!
PostPosted: Sun Nov 20, 2005 7:38 pm
Yeah it will fit but the turbo will need to be moved over the top of the gearbox, or you could cheat and extend the front of the car.
As far as the subframe goes you will need to construct it yourself. I dont think anybody has done a flipfront 4efte conversion yet. Also you should check with the RTA if you are allowed to have a flipfront ???
You will find most people on this forum will help with info about subrame inc pictures etc. As you start building just ask.
Dan
PostPosted: Sun Nov 20, 2005 8:14 pm
You can mount the turbo using the standard starlet ex mani and turbo. The wastegate actuator is what causes some space issues. Easy enough to piss that off alltogether.
PostPosted: Sun Nov 20, 2005 9:16 pm
I just went down to the garage and measured up the stock manifold and turbo. The stock manifold is approximately 115mm of the head and the turbo another say 25mm. from the side of my head to the outside face of the front panel (top bar where the bonnet catch is located) i have 115mm, that would mean you would have to modify your grille to sit further out and cut into the lower section of your front panel.
Also my motor is as far back as it can go, the water pump pully is approx 4mm of the drivers tower and the passengers side CV (without the rubberboot) is about 8mm of the inner tower (see previous posts for photos).
Note i have also made solid mounts which will stop my motor from moving under load around as much as a standard one.
Dan
PostPosted: Mon Nov 21, 2005 8:33 am
Dan,
What part of the 'turbo' would foul the grille? Is it the two mounting lugs for the wastegate actuator? That is all that appears to be protruding into the 'line' of the where the grille might sit.
I'm ditching the mech water pump and fit a leccy water pump. This will give me a little more room.
JC
PostPosted: Mon Nov 21, 2005 8:55 am
moving the turbo over the gearbox doesnt bother me at all...since i am prolly going for a flip front (dunno yet, am calling John Kean from DoT sometime this morning to make sure its all nice and legal) room under the hood will be fairly large...
nobody in AU has attempted a flip-front roundnose 4e-fte conversion???...dont usually like being a trailblazer...but meh :P
this just in: John reckons that i need to fill out a "permission to modify" form from QLD transport and send in drawings n stuff of what i wanna do...then it will either be approved or declined...this is for the flip-front btw...
Bling me up Scotty!
PostPosted: Mon Nov 21, 2005 6:57 pm
so...that guy has his radiator sitting over the gearbox...nice work there...but if i wanna put the turbo there...where the hell do you put the radiator? :P
Bling me up Scotty!
PostPosted: Mon Nov 21, 2005 7:20 pm
Back next to the front wheel like a mini :?:
PostPosted: Mon Nov 21, 2005 7:23 pm
spose you could if you got a smaller radiator...would that provide enuff cooling though? starting to think this gt conversion is a pain in the arse...and i should just go with a gti and turbo that...what do you guys reckon?
Bling me up Scotty!
PostPosted: Mon Nov 21, 2005 7:32 pm
Starlet GT was made for turbocharging - I'd go with that
PostPosted: Mon Nov 21, 2005 7:39 pm
thats what i want...just need to work out where to put everything :P
Bling me up Scotty!
PostPosted: Mon Nov 21, 2005 8:11 pm
I'll try and post photos of Andy's roundnose when it was in its early stages and see how the turb looked.
Inazuma, don't lose faith before you start, go the roundnose with the efte, enjoy the challenge that the conversion brings.
Dan
PostPosted: Mon Nov 21, 2005 8:20 pm
dont worry :) i wont lose faith or enthusiasm for this...i have come to realise that the 4e-fte is the answer to all of the things i've wanted out of my mini...power...reliability...with all the looks of a roundnose (which i love...sorry clubman fans...i just cant bring myself to get one)
Bling me up Scotty!
PostPosted: Mon Nov 21, 2005 8:23 pm
Good stuff.
If you need any photos let me know and I'll happily email them to you.
Dan
PostPosted: Mon Nov 21, 2005 8:30 pm
photos'd be fab!
Bling me up Scotty!
