It is currently Thu Jul 03, 2025 11:02 am
 Post subject: Sand Blasting
PostPosted: Mon Nov 21, 2005 5:33 pm
Looking at getting my roundie shell sand blasted ... how much should i expect to pay?
PostPosted: Mon Nov 21, 2005 6:36 pm
i think the going rate a couple of years ago was $500??
1974 Moke - 998cc
PostPosted: Mon Nov 21, 2005 6:40 pm
$500 hey :) i have heard rumours of prices between $400-$600 ... so id be happy with that :)
Anyone else?
PostPosted: Mon Nov 21, 2005 7:08 pm
i can pour a bucket of sand over it for 20 bucks including the sand :lol: :lol:
Perhaps it would be better bead blasting as i have heard rhumours saying that after sandblasting there isnt much mini left as they used bog from factory :( :(
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Mon Nov 21, 2005 7:19 pm
bead blasting and sand blasting ... other then the obvious of using beads and sand to blast the car, whats the difference?
PostPosted: Mon Nov 21, 2005 7:36 pm
Glass or plastic beads?
They both tend to remove the paint but are not as abrasive & dont take off as much of the parent metal. Glass beading is used on parts & tends to polish the surface.
Plastic bead blasting is cheaper than glass beading & will give a good clean surface.
Both are more expensive than sandblasting. Sandblasting is fine if done right, with a nice fine grit.
PostPosted: Tue Nov 22, 2005 12:32 am
just had my van body sandblasted with garnet at vintage & classic auto blast , turned out fantastic really happy with the job andy done," that man is a down right legend" highly recommend him to anyone :D
live life to the full as yesterdays gone, & tommorow never comes.
1974 LEYLAND P/VAN
PostPosted: Tue Nov 22, 2005 6:52 am
I had a renault bodyshell glass bead-blasted over 10 yrs ago, and it cost nearly $700. I recko n it would be $1000 now, but ring for a quote. It is gentler and more preferred than sand-blasting per se as others have mentioned
The place who did it was Impact Glass Blasting in Romford Place Blacktown (just off Sunnyholt Rd).
The other alternative is dipping to chemically strip. Redi-strip in Bessemer St Blacktown (again, off Sunnyholt Rd). I had guards, bonnet, doors etc chemically stripped by them and they also came up really well. They can do whole bodyshells also. There also used to be a similar place in Revesby I think, but I haven't delt with them.
Word of warning - Either if done properly, will take every bit of paint off. At the factory, they quite often dipped the shells to let paint run into the nooks and cranny's, then traditionally spray painted the rest. Once you start spraying a bare shell at home, it is hard to get paint into some of those places again. Everyone talks about "bare-shell" resprays & resto's. That's not always the best for the car in the long run. Fortunately, a mini shell is probably easier in that respect than a lot of other cars.
Good Luck.
PostPosted: Thu Nov 24, 2005 9:06 pm
so what would be the best way to sand a shell back???
random orbital sander, paint stripper, sand blasting ????
My rides-74 fj40
PostPosted: Fri Nov 25, 2005 2:15 am
Best & cheapest - hand sanding. PITA though :x
Quickest & most efficient - sand blasting.
PostPosted: Fri Nov 25, 2005 6:50 am
Smelliest = paint stripper. Put gladwrap on it to hold the fumes in, it works much better. 8)
