It is currently Sun Jun 22, 2025 12:59 am
PostPosted: Thu Aug 26, 2004 9:07 pm
val man's talking about my morry. the flip front.
we're looking at a supercharge option, just wanna know the best way to go. $5K is very steep. i would have thought $2k max.. stingey fudgepackers :evil:
PostPosted: Fri Aug 27, 2004 12:48 am
The price may have dropped since i last checked..... email them for info - they might have a cheaper option....
PostPosted: Fri Aug 27, 2004 7:16 pm
Hi Mike. Thank you for your enquiry.
Our supercharger kit is designed to be fitted to a basically stock engine.
Provided the engine is in good condition, and within manufacturers tolerances there is generally no extraordinary mods. required in the milder stages of tune.
Bearing in mind that some of these vehicles are now nearly 40 years old, and more than likely, have been rebuilt or modified from the standard specification, this must be taken into account when designing a successful supercharger system. Many rebuilt engines have a higher than original comp. ratio, and camshaft changes are often made at the time of rebuild.
However, many mod's which work with conventional tuning can also be successfully employed on supercharged applications.
Generally we find that the 96 octane (roughly similar to 91 US) fuel available here is the limiting factor in safe power production.
Therefore we need to ascertain the actual ratio of each individual vehicle to establish just how much boost could safely be used. We tailor each kit to suit chosen engine spec. and available fuel octane.
Excellent results have been possible with 8.0 and 8.5: 1 comp. ratios.
Prior to delivery we will require the following engine details:
Bore size
Stroke
Compression ratio,
Camshaft timing profile,
Fuel (octane rating) available
Power would start around 30% improvement over standard and could reach 100% given the correct set-up.
In our kit fuel requirements are taken of by the SU HIF 6 carby supplied (the metering needle fitted may require slight changes to suit each individual installation). The distributor advance curve should, ideally, be modified to suit the engine's new requirement, or we can supply a brand new Bosch distributor with a suitable curve.
Our comprehensive kit includes all components (incl. new SU carby and K&N filter) to convert a standard Mini to a supercharged Mini, including detailed fitting notes.
The price of our Mini kit is $5375 AUD plus GST.
Regards,
Hans J. Pedersen
HP High Performance Products
Victoria. Australia
Ph. +61 3 9874 1800
http://www.hi-flow.com
[email protected]
pfft.
PostPosted: Fri Aug 27, 2004 8:27 pm
did i just read 5375 for a "30-100%" power increase that wont have the right needle and thus will ideally need pulling out of the car and have 500+ bucks woth of dynotuning to set up right? :shock:
G
PostPosted: Fri Aug 27, 2004 9:36 pm
No - you missed the "Plus GST" part
PostPosted: Fri Aug 27, 2004 10:28 pm
yer a 777-200 engine would be cheaper
PostPosted: Sat Aug 28, 2004 12:29 am
now email him back and say "I dont need a WHOLE mini, just the supercharger"
*notice the distributor was not included in the price either :lol:
....and i thought it was gonna be cheaper.... SHEESH :roll:
Users browsing this forum: No registered users and 29 guests
