It is currently Thu Jul 03, 2025 7:15 am
PostPosted: Sat Nov 12, 2005 7:50 pm
is this a brake booster or something?
http://imagestore.ugbox.net/aview/eedb2 ... f47fbaa17e
it seems that i have to remove it in order to get the front subframe out...is this the case?
Bling me up Scotty!
PostPosted: Sat Nov 12, 2005 7:55 pm
I think it's a horn.
PostPosted: Sat Nov 12, 2005 7:58 pm
spose that would make sense...i'll take it out either way :P
Bling me up Scotty!
PostPosted: Sat Nov 12, 2005 8:22 pm
yep its a horn - never seen one down there before though
PostPosted: Sat Nov 12, 2005 8:37 pm
yer thats the horn, my deluxes one is there too, thats the only mini that has em there i think, the rest are on the other side on the inner guard to my knoledge, but yer, just a horn
Potato
PostPosted: Sat Nov 12, 2005 8:41 pm
BMC carefully positioned it there to make it bloody near impossible to get the oil filter out. Without spilling it. :lol:
I guess at least it doesn't crack the bodywork and fall off, like Clubby ones- including ours did. :wink:
PostPosted: Sat Nov 12, 2005 11:39 pm
was a bit surprised...especially since the passenger side brake lines go right under it...hence why i thought it was a brake booster or something...do i just undo the nut ontop? or is there some other way of getting it off?
Bling me up Scotty!
PostPosted: Sun Nov 13, 2005 5:30 am
its attched to the subframe underneath..nut and bolt
get the jack and axle stands out :wink:
PostPosted: Mon Nov 14, 2005 7:38 pm
hehe yer definately a horn :oops:
PostPosted: Tue Nov 15, 2005 7:57 am
can it be reconfigured to play la cucaracha? :lol:
Bling me up Scotty!
PostPosted: Tue Nov 15, 2005 1:37 pm
Hi
Just get a 7/16 socket (1/4" drive is best with a 2" extension.) into the spce under the lip of the subframe to hold the nuts, then use a 7/16" spanner to turn the bolt on the outside of the subframe and the whole thing lifts away. (2 bolts in the horizontal plane)
Matt
PostPosted: Tue Nov 15, 2005 8:23 pm
Go air horns! if they can't see you, they definately will hear you! :wink:
PostPosted: Wed Nov 16, 2005 7:56 am
as long as they play la cucaracha....I'M THERE!
Bling me up Scotty!
Users browsing this forum: No registered users and 36 guests
