It is currently Sun Jun 22, 2025 10:07 am
 Post subject: Suzuki GTI info
PostPosted: Sun Nov 13, 2005 7:22 am
Hi Guys
I have just brought a Suzuki GTI motor it didnt come with a Harness ,ECU or Gearbox can you advise me on the on the best way to go either Suzuki ECU or an after market brand also is there any difference between the GTI Gearbox and the standard Swift Box
Cheers Wayne
 Post subject: gti info
PostPosted: Sun Nov 13, 2005 9:42 am
Gday mate having owned a swift gti And blown up the gearbox and put and standard box back in the gti box has a higher diff ratio for the higher revving twin cam motor but strenght is the same as my swift was turbo charged and the barina box stood up better than the gti box.
I had aftermarket injection in mine but if you have to get it approved after market wont be allowed .
Thanks Ralph.
PostPosted: Sun Nov 13, 2005 2:39 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hey wayne do you own a terrapin or did you purches ot recently from giuldford ???
makka
PostPosted: Sun Nov 13, 2005 5:46 pm
Hi Makka I built my Terrapin but would be interested in any info you have on the one in Giuldford
PostPosted: Sun Nov 13, 2005 6:31 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
well it was for sale 4'500 i'll contact the owner to see if he still has it
i love the way you lay in it :)
makka
 Post subject: Re: Suzuki GTI info
PostPosted: Mon Nov 14, 2005 9:02 am
Terrapin25 wrote:
Hi Guys
Cheers Wayne
I think the ratios are closer together. Diff ratio is different and all the GTi guys reckon the GTi box is stronger. Check out www.teamswift.net and www.redlinegti.com and you should find the answers you need.
If you have no harness or ECU I would be inclined to go for aftermarket. If you want to keep the cost to a minimum you should try to get an original harness & ECU but I think in the long run you would be better off with aftermarket because. The extra cost would be worth it (IMO) because you can tune it. Also, You are really going to want to strip out all the extra stuff from the original loom that you wont be using. This can be tedious.
PostPosted: Mon Nov 14, 2005 9:30 am
check to make sure that your engineer will allow an aftermarket ECU. Both engineers that I talked to said that it could only be a piggyback style ECU.
The wiring harness for the GTI is not that bad actually. It took me 3 hours to pull out what I needed for my GTi. The best thing is to download the manual and look at the wiring diagrams.
The only things that I am not sure of is the compatibility of the GTi oil pressure sender, temp sender units that they will work with the stocko mini gauges. or lights.
PostPosted: Mon Nov 14, 2005 9:51 am
on the gearboxs as regards strength i am reasonable convinced the strength wise between the twor there is no difference
the gti has closer ratios
standard suzi or barina box better suited for mini 10 inchs
PostPosted: Mon Nov 14, 2005 10:35 am
Thank for the help guys being able to use a Swift or Barina box will make life a lot easier as for the ECU I think I will look around for the standard GTI unit
PostPosted: Mon Nov 14, 2005 6:09 pm
I think the diff ratios are identical on gti and standard swifts (both 4.105), but GTi boxes are indeed closer ratio, and have a lower ratio 5th gear. As for strength, i belive there identical.. I know of 2 people running swift cino boxes in turbo swifts, and although they do eventually break, it seems to be no quicker than with a GTi box.
I intend to use a swift cino box in my mini, I reckon as I can get them for $100 or less versus $350+ for a GTi box, I can afford to break a few.. :)
Andrew
PostPosted: Mon Nov 14, 2005 8:37 pm
I have heard from a few people that the GTI boxs are stronger? They are definatly alot more expensive...
Life's a garden.... Dig It!
PostPosted: Mon Nov 14, 2005 9:20 pm
thats because they have GTi stamped on it
from what i have heard the common thoughts are it wont last any shorter the a suzuki box
the stocko suzuki has a taller 5th
PostPosted: Tue Nov 15, 2005 11:05 am
i have a std box if you wont to buy 1
Twincam GTi Powerd mini
 Post subject: GTI
PostPosted: Tue Nov 15, 2005 9:43 pm
Diff ratios Mk2 & 3
GTI 4.105
Cino/Swift/Barina 3.523 & I have seen 3.9
The GTI has a different bellhousing with an extra bolt for a caste
iron stifferner to bolt to the front of the block
Blue
Keep shiny side up
PostPosted: Wed Nov 16, 2005 7:18 am
Thanks for the Gearbox offer however I need the complete Drivetrain so I will be looking for a Wreck or front cut
