It is currently Thu Jul 03, 2025 7:16 am
Which engine should I use for an sc12 conversion?
850 10%  10%  [ 2 ]
998 15%  15%  [ 3 ]
998 with 1100 head 20%  20%  [ 4 ]
1100 10%  10%  [ 2 ]
1275 25%  25%  [ 5 ]
1330 20%  20%  [ 4 ]
Total votes : 20
 Post subject: SC12 on which engine?
PostPosted: Fri Nov 11, 2005 10:18 am
Which engine would I be better off running an sc12 supercharger on? Fuel efficiency isnt really a concern ... i want a car that'll be quick
PostPosted: Fri Nov 11, 2005 11:36 am
There will be a bigger gain in torque with a 1275 (or 1330)
You will hardly find any 1275 blocks around on their original bore
- just take to the next oversize, 1310 , 1330
PostPosted: Fri Nov 11, 2005 11:54 am
id do an 850 just to be different and you can pick up one for nothing :wink:
PostPosted: Fri Nov 11, 2005 5:08 pm
I dont want to be "different" ... i want something with POWER!
PostPosted: Fri Nov 11, 2005 6:08 pm
there ain't no substitute for 'cubes ;)
PostPosted: Fri Nov 11, 2005 6:09 pm
I was thinking 1330 with sc12 running through a weber or delorto ... but kinda heard that a 998 with an 1100 head was good too?
PostPosted: Fri Nov 11, 2005 6:14 pm
good luck getting it to work with a webber or dellorto..i'd like to see it done 8)
a 998 may be good, might make similar power to an Naturally Aspirated 13XX...
PostPosted: Fri Nov 11, 2005 6:16 pm
Just because its what i want, doesnt mean itll happen :)
PostPosted: Fri Nov 11, 2005 6:26 pm
My wife tells me that all the time :(
PostPosted: Fri Nov 11, 2005 6:34 pm
Bloody minister for finance and recreation!
PostPosted: Fri Nov 11, 2005 7:48 pm
Ask 100 time and you get it 20 times :?:
Ask 20 time and you get it once :!:
:wink:
PostPosted: Fri Nov 11, 2005 8:02 pm
It will work fine with a Weber or Dellorto, suck-thru is easiest with a S/C.
But a big SU just as good I reckon.
Size? 1275-1330. Over that the cylinder walls are a bit thin for forced induction.
PostPosted: Fri Nov 11, 2005 8:18 pm
FFS do the maths people.
Whats gonna be quicker, standard?
an 850 or a 1275.
Hmmmm :roll:
/**** rant.
PostPosted: Sat Nov 12, 2005 8:37 am
Okay looks like im going to run with a 1330 and the sc12 sucking through a kick ass su carby or weber :)
Thanx guys
Lucas
PostPosted: Sat Nov 12, 2005 8:51 am
mnmmn i just looked at the results and zero for 1100s i would have thought behind a big block this would be the go because of its torque which it has standard
i would love to try one on a worked 1100
Users browsing this forum: No registered users and 38 guests
