It is currently Sat Jun 21, 2025 11:41 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Nov 07, 2005 10:02 pm
Mick I may just take you up on that offer! Thanks mate yeah not concours but was never attempting that, once I have it on the road for a year or two I will do the suburst orange and black racing stripes...By the way once on the road I have big plans for the radiator and intercooler setup. Its gelling in my head as we speak but rego first... :wink:
 Post subject: Steady.....
PostPosted: Tue Nov 08, 2005 8:15 pm
If it was me....I would leave it plain brown wrapper....in the olden days they were called Q Cars...or sleepers nowadays :shock:
The look on the faces of the high priced performance car people is priceless....I will never (ever, ever) forget the times we had in a mates full-house FC 3/4 race dunger that we used to regularly hose off Porsches etc
8) 8) 8)
PostPosted: Thu Nov 10, 2005 10:04 pm
Well guys finally finished of the EFI system from front to back. So many skinned knuckles! Now onto the electrickery... :lol: :?
PostPosted: Thu Nov 10, 2005 10:13 pm
You got a vent line from the tank?
Tank must be non vented cap!
PostPosted: Fri Nov 11, 2005 7:06 am
Umm AWD please explain :? I need a non vented fuel cap but run vent lines from the tanks themselves is that what your saying. Do you know where I can get these non vented caps???
PostPosted: Fri Nov 11, 2005 11:58 am
Yes. Vent line must end up in your little black charcoal cannister.
I believe the later model UK cars had non vented caps, but have not seen them myself.
If your engineer isn't pushing for it, I wouldn't worry. Mine did - was one of the first things he told me. I made up a custom alloy tank - there's no replacement for Moke top fill lids anyway :roll:
PostPosted: Sat Nov 12, 2005 7:55 pm
Minstar,
Looks like your almost there. Looking good.
Dan
PostPosted: Sat Nov 12, 2005 10:27 pm
Thanks Dan, much appreciated. Yeah getting close now. I have done the strut brace that my engineer required (goes from the firewall to the lefthand engine mount) and started putting in the electrics today. What a mess :? :D
Matt
PostPosted: Sun Nov 13, 2005 2:49 pm
Matt,
I am a bit suprised about the strut that your engineer made you put in considering all the bracing in your subframe ( you seem to have the most out all the efte mini's) anyway I suppose you have to keep the engineer happy. Is the brace rubber mounted or direct fix to the firewall?
Dan
PostPosted: Sun Nov 13, 2005 9:02 pm
Yeah Dan I certainly didn't think it was a weak subframe! If anything it is a little overengineered. He said it was mainly about making the subframe last a decade instead of 3 years. That mount is right at the end of the right spar so is under more load than anywhere else in the sufbrame so the strut just gives it that little bit more oomph (technical term :wink: ). I have put a rubber pad between the strut and the mount. The picture below of the finished product gives a better idea...
Also started the electrics!!!!!!!!!!!!!!!!!!!!!!!!!!! :roll: :D 8)
PostPosted: Mon Nov 14, 2005 11:59 am
Well done!!!
Dan
PostPosted: Mon Nov 14, 2005 1:23 pm
thats looking great i think its going to be a very neat install once done and go pretty damn hard :evil:
 Post subject: Obvious
PostPosted: Mon Nov 14, 2005 5:27 pm
[quote="minstar"]Also started the electrics!!!!!!!!!!!!!!!!!!!!!!!!!!! :roll: :D 8) quote]
Completely overstating the blindingly obvious, but, start by trying to "dress" the loom as it was in the front cut....once its all laid out....then look at ways of clipping it to firewall etc...have fun :D
PostPosted: Mon Nov 14, 2005 9:52 pm
Mick, yeah that is pretty much what I have done the trouble is I am trying to remember something I did in late July 2004! But tonight I managed to isolate the leads for the starter motor and the alternator which were the two biggies. And it looks like my number tags are working. I should have most of it in over the weekend!
PostPosted: Mon Nov 14, 2005 9:57 pm
Very Very Nice Minstar...
You will be a expert after this...
Good Luck... we need to catchup soon
Baracade
Users browsing this forum: No registered users and 26 guests
