It is currently Mon Jun 23, 2025 10:58 pm
 Post subject: gti swap
PostPosted: Sat Nov 05, 2005 3:41 pm
g,day guys.just curious in knowing what is involved in a gti swap into a clubby?does the inner guards have to be cut a lot?not interested in a turbo version,just a non aspirated 5 speed.want to build a cruiser that doesnt rev its nut off at 120kph.also is the rego guys gonna be a prob in sydney?thanks cheers :)
 Post subject: Re: gti swap
PostPosted: Sun Nov 06, 2005 4:21 am
I suppose it depends on what your definition of a lot is :) The passenger's side needs to be cut away to allow room for the transmission. On the driver's side the engine itself fits within the confines of the inner guard, although room is scarce when it comes to ancilliaries (eg, alternator). Most guys reverse mount the alt and have it poking through a hole in the inner guard, though I have also seen pics of it mounted over the transmission and being powered via a shaft that is mounted to the front of the engine (not sure if that would go behind or in front of the enhaust manifold). GTi_Clubby has some good pics in this thread
As for revving it's nuts off, I think you will still need to look at gearing. I am pretty sure the GTi uses a larger dia wheel & tyre combo than can be practically fit to a mini, so a taller diff would be in order if you want to maintain similar revs to the GTi. I do know that a couple of different ratios are available in the Swifts, so you can probably do some mixing & matching. I did make a spreadsheet to calculate this for 4WDs (another hobby of mine) if I can dig it up i'll modify it to suit.
You shouldn't have a problem with rego in NSW. Hopefully one of those guys will chime in, but i'd suggest you see an engineer or equivalent before you start.
EDIT: added URL to GTi_Clubby's thread
PostPosted: Sun Nov 06, 2005 7:24 am
Yeah as of yesterday i am the proud owner of a suzuki swift Gti thanks to striped 63
theres a bit to do as you would expect with any engine conversion
Things that need changing for sure
subframe needs building/changing
some minor body mods very minor really and thats in a roundy in a clubby hardly any if any at all
drive shafts need to be changed for obvious reasons can turn them down or cut and weld half a mini shaft to half a gti or get some sexy ones made up
need disks with dual cylinders and circuit
a little fabricating here and there
wire it all up
and yeah your getting close
i would have missed something so add please
and on the box ratio i think suzukis came with 14s wheels so if you put 10s on it will be revvy on open roads still better then a mini but still not great have been told that a holden 89 Barina box fits without and mods to anything and has a great drive for 10 inch wheels giving like 106 mph at 3 G revs :shock:
which is a little better then my stocko 998 which gives about 106kmph at 26000 revs :roll:
PostPosted: Sun Nov 06, 2005 12:23 pm
Yeah, the barina and swift cino boxes are a better bet for lower crusing rpm with 10in wheels, as they have a higher ratio 5th gear.. (0.757 vs 0.870 for std GTi box).. Both boxes have the same final drive ratio (4.105)
I'm not sure about 10 inch wheels, but on 12's it think it works out to be about 3300 rpm @100km/h with cino box or 3800rpm @100km/h with gti box (Both in 5th gear of course..)
Andrew
PostPosted: Sun Nov 06, 2005 1:00 pm
thanks for the info guys.cheers
PostPosted: Sun Nov 06, 2005 6:09 pm
Andrew
AFAIK the GTi boxes are a bit stronger and have closer gearing. If possible i'd rather stay with the GTi box and just change the diff ratio.
PostPosted: Sun Nov 06, 2005 7:03 pm
GTI boxes are not that strong.. my mate had his stocko one go bang at 100,000km... :cry:
I doubt a Barina box is much weaker.
PostPosted: Mon Nov 07, 2005 5:43 pm
From what I've heard/read on the net, GTi boxes and standard swift boxes are identical in strength, Gti's just have a closer ratio gearset, but i could be wrong.. apparantly MK1 GTi's have stronger diffs though.
Quite a few people use the swift cino boxes when they do turbo conversions, as the ratios are better suited, but i think they all a bit weak, regardless of what you use
Andrew
PostPosted: Mon Nov 07, 2005 6:39 pm
i was talking to blumin about the gear boxes a while back and he said the cino boxes were more mini friendly as the boxes were designed around 12 or 13 inch wheels rather than the 14s on the gti.
lookin for another clubby
 Post subject: GTI
PostPosted: Tue Nov 15, 2005 10:13 pm
I'll post this one more time
Suzuki gearboxes Mk2 & 3
Diff ratios GTI 4.105
Cino/Swift/Barina 3.523 & 3.9
The GTI box is not desireable for 10" or 12" wheels
unless you want to climb verticle walls
The GTI & Swift etc diffs are not interchangeable
No part of a Mk1 box will fit a Mk2/3 box (gears diff etc)
Cutting & shutting driveshafts is highly dangerous & illegal
Blue
Keep shiny side up
Users browsing this forum: No registered users and 24 guests
