It is currently Thu Jul 03, 2025 3:36 pm
PostPosted: Thu Nov 03, 2005 8:13 am
O GOD THE MEXICANS ARE COMING :shock:
PostPosted: Thu Nov 03, 2005 10:33 am
Slow-Po
Whatchoo talkin' bout, we're already here!
PostPosted: Thu Nov 03, 2005 8:09 pm
you can get air-assisted shockies... maybe you could run your car on the standard suspension and then flick a switch for the increase in ride height to clear your objects...
Not sure if you can get the shockies the right length for the mini.
I actually have some goodyear airbags at work, which are the same diameter as the rubber cones. The only problem is that with the low weight of the mini, they will make the car feel like a bloody sponge.
 Post subject: air bags
PostPosted: Thu Nov 03, 2005 8:21 pm
how much do you want for the airbags
will they go straight in or do i have to modify heeps thanks for the replay but
cheers pazz
