It is currently Wed Jul 02, 2025 5:19 pm
 Post subject: engina reco
PostPosted: Mon Oct 24, 2005 6:56 pm
ok people i just wanna know if therz anytin i left out in the parts needed to recondition my 998, assuming the engine is in fairly good nick ie no rebore and pistons( cus thats a boring process haha)
copy and paste any more that i forgot......
Valve Locks
Valve stem seals
Cam Followers but not bearings cus their hard to do but dont get worn very much
Oil pump
Electric fuel pump
Water pump
Rings
Crank Journals, bearings with thrust washers to suit.
Timing Chain Tensioner and timing chain
Wire brushes for the head.
Rings
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Tue Oct 25, 2005 11:28 pm
Dis is da stuff dat i need - FINAL LIST
Parts that I will neeed:
Valve locks, 8 pairs
Valve stem seals, 8 off
Cam followers, 8 off
Oil pump
Oil pump locktabs
Main bearings
Big end bearings
Big end locktabs, 4 off
Timing chain tensioner
Double row timing chain
Piston rings
Flywheel ring gear
Harmonic balancer locktab
Timing cover oil seal
Water pump
Lower radiator hose
Expansion hose
Thermostat
Gearbox input shaft/clutch housing bearing
Gearbox idler gear/clutch housing bearing
Gearbox/engine flange gaskets
Clutch housing/engine gasket
Clutch housing oil seal
Clutch locktabs
Clutch housing locktabs
Clutch kit (pressure plate, driven plate, throwout bearing)
Inner drive shaft joint rebuild kit (ball bearings?), 2 off
Head port & polish kit ;-)
My rides-74 fj40
PostPosted: Fri Nov 11, 2005 3:24 pm
oops,,,forgot the turbo & injection assys
PostPosted: Fri Nov 11, 2005 3:40 pm
Don't forget to budget for the often overlooked
Oil and filter for runin
Oil and filter after runin
Coolant
Plugs
Points?
Dizzy cap and rotor?
you have stated the gearbox and clutch gaskets but you're going to use an entire long motor set of gaskets
Good luck with the project
PostPosted: Sat Nov 12, 2005 4:29 pm
Did i leave out the possiblity of supercharging,nos,nah im startin the 4efte next year anyway and that will have all that.....
Yeh i'll b buyin oil coolant filterz, plugs, i dont know bout the contacts as i might do a pulsar dizzy :lol:
I'm hopin for the engine to be done by like end of january..that'll give me time to work on all the other little pieces of sheite thats stoppin it from passin rego
Another thing that surprised me was that this engine had PERFECT Cylinders and the crank was still in spec...not too bad hey
I bought meself some autometer white faced guages (oil,water,volts and tacho) just to keep me from blowin it..then i would have to start again :(
My rides-74 fj40
