It is currently Sat Jul 19, 2025 2:38 am
 Post subject: Exhaust
PostPosted: Wed Oct 12, 2005 2:50 pm
I have been informed that I need to comply with a noise test. For my mini gti motor, I have a hotdog and a muffler (straight through, steel wool packed type)
Will it pass or do I need to add some more mufflers/hotdogs. Or do I just stick a restrictor in the xhaust and pull it out later...?
How much do these other tests cost?
Brake, Noise, emmissions etc.
Thanks
 Post subject: Re: Exhaust
PostPosted: Wed Oct 12, 2005 2:55 pm
manofaus wrote:
Will it pass or do I need to add some more mufflers/hotdogs....
You may do, for the test anyway........... After that...."Mini's didn't come fitted with mufflers, Orrificer"
PostPosted: Wed Oct 12, 2005 3:10 pm
I would think that you should be OK
Do you know anyone in the music or ICE game?
They might be able to lend you a dB meter to get a reasonably accurate measurement.
PostPosted: Wed Oct 12, 2005 3:15 pm
duh.. should have thought of it earlier..
we have such a beast at out work.
also he mentioned a speedo calibration test.
PostPosted: Wed Oct 12, 2005 3:19 pm
Are you planning on running on a dyno?
You can check the speedo then.
PostPosted: Thu Oct 13, 2005 12:52 pm
AWD et al, I am running 12x5's on mine, given that that will obviously throw out the starlet speedo what is involved in recalibrating? Also I am running 2.5" straight thru (no hotdogs etc) and a straighthru muffler (Lukey) hope that gets through?
PostPosted: Thu Oct 13, 2005 1:03 pm
Ministar,
You should be OK with a straight through set-up. I once did this on a 1600 (Datto) it had a CA18ET in it and i never had an issue with it.
Suprisingly it was a very quiet car.
Daniel
PostPosted: Thu Oct 13, 2005 1:10 pm
You have a digital speedo input? (i.e. not cable drive)
There is a digital interceptor which you can adjust to whatever speed you need.
Will look up the details & post here, as I have already thought about it - may need one myself.
If it's cable drive, most auto sparkies can change the cable drive gears to correct it.
PostPosted: Thu Oct 13, 2005 1:17 pm
Thanks for the advice guys (sorry to hijack your thread manof). I guess we will find our shortly.
PostPosted: Thu Oct 13, 2005 2:35 pm
if you go to.. castlemainerodshop.com.au they can sell you this correcting thingamagig for both electronic and cable drives.. from memory about 200 bucks.
or if you can use a soildering iron:
http://www.jaycar.com.au/productView.as ... &SUBCATID=
alot cheaper.....
from what I was told the gti has a cable speedo... I can get a new cable made up at castlemaine and use corrector gearset. ... from what I remember.......
PostPosted: Thu Oct 13, 2005 3:11 pm
The Jaycar one was the unit I was looking at (as featured on Autospeed).
But I'm not sure I will need it. I am running 186/65 Pirellis on 14" mags.
Not sure how that compares with the standard rims it came out with.
I believe the Australian standard only requires speedos to be +/-10%,
so I have a fairly wide margin to work in.
PostPosted: Thu Oct 13, 2005 4:45 pm
starlet is cable driven.
1974 Moke - 998cc
PostPosted: Thu Oct 13, 2005 5:10 pm
OK you can sort out speedo woes here:
http://forums.ausmini.com/viewtopic.php?p=164968
and get back onto exhausts :wink:
PostPosted: Thu Oct 13, 2005 5:34 pm
kinda sort.. do all speedos have the same ratio? I thought that they were more then likely different.
PostPosted: Thu Oct 13, 2005 6:48 pm
Different makes/models/spec level cars all can have different speedo drive ratios.
I posted the rolling diameter link up so that you could check how far out your speedo will be if you compare your new rims against the stock factory rims/tyres for the suzuki.
I believe you can get away with being 10% out & still pass inspection (but don't quote me on that)
but of course if the speedos are never perfect from new,
and if it was already 5% high you would now read 15% high
but if it was already 5% low you would now only read 5% high
Users browsing this forum: No registered users and 24 guests
