It is currently Tue Jun 24, 2025 8:00 pm
PostPosted: Tue Aug 17, 2004 8:04 pm
I tried the `lets add some metho' thing with my boat tank once. No it didn't work, and I put a fair bit in.. :cry:
 Post subject: Metho displaces water
PostPosted: Tue Aug 17, 2004 8:16 pm
Doc did you have more water than fuel in the tank or what?
Metho will definately displace the normal amount of condensation you get in the average tank - maybe a few doses with each fill may be required or in your case maybe a full flush out of the tank and lines were required :wink:
PostPosted: Tue Aug 17, 2004 9:16 pm
Boat had a 45L cruisetank. It had about 1 cupful of water in it. I put 400ml of metho in, to see what happened. Then I poured it all out into a plastic bottle.
It just stratified- dirty water on bottom, then metho, then fuel on top. OK- so fuel was 2 stroke mix- but I doubt that would matter.
Anyhow no more problem- I sold that boat. The one I got now has 2 portable tanks- I just run each until empty.. :wink:
PostPosted: Tue Aug 17, 2004 10:17 pm
:lol: doc - you'd need about 2 gallons of metho to take care of that much water :? The oil in the two stroke won't mix with metho - only oil to mix with metho(alcohol) is castor oil
As an aside : Castor Oil also does not attack rubber so if you have a dry squeeky rubber bush you can mix about 25% Castor Oil in metho and squirt/spray it between the bush and the metal and it will shut it up and not damage the rubber.
David L
