It is currently Wed Jul 02, 2025 9:56 pm
 Post subject: Dashes from other cars
PostPosted: Mon Oct 10, 2005 11:05 am
Hi all how hard is it and whats needed to fit a dash with instrumnents from other cars to minis? Is the wiring hard to figure out or not compatible at all
for example if i wanted to install this dash from an EH into my clubbie what would i need to do?
or this instrument cluster from a yamaha bike
Im not saying i want either im just using them as examples
thanks
trent
PostPosted: Mon Oct 10, 2005 4:45 pm
I'm not too sure, never had to do one.. But if you can't work out the wiring I'd sugest getting a manual for the car the instrument cluster came off and use the wiring diagram in that to work it out.
PostPosted: Mon Oct 10, 2005 5:04 pm
If the speedo you are using is electronic it might be a bit more difficult (as I presume the Yamaha's speedo is). Brad just put thecluster from a Subaru in the 'basher' so he could tell you more :wink: I guess it all depends what you want to put in there decide that and work from there. :D
Roads need more corners
PostPosted: Mon Oct 10, 2005 8:03 pm
I cant think of why it wouldnt work, its all just 12 volt isnt it, Sure speedo cable connectors might be a lil different, but if i install a dash from another car thats a 4 cylinder theres no reason why tachos should be out is there..................hmmmmmm maybe a trip to a wrekers is in order
trent
PostPosted: Mon Oct 10, 2005 8:45 pm
The tacho wouldnt be too hard to make work......but the speedo could....not all cars have speedo cables.....especially a digital dash like that bike one...it would have a speed sensor somewhere which sends mesages to the ECU....the ECU then converts that to road speed and tells the LCD what to display.....
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
