It is currently Tue Jul 01, 2025 9:43 pm
 Post subject: Larger Oil Filter
PostPosted: Tue Sep 20, 2005 2:14 pm
I have Fitted a Ford Falcon Filter (Valvoline No V03)
First of all you need to have a Spin On Type of filter housing.
Remove the housing and Make a Spacer out of 3mm Aluminum. Trace around a Gasket for the housing.
Trial Fitt and see where the filter hits the Subframe.
Remove the small portion from the subframe with a Grinder.
Refite housing and check if all ok.
Fit using 2 Gaskets and away you go with a larger Oil Filter for less then Half the Cost of a Mini one.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Wed Sep 21, 2005 6:55 am
Late 70s VW Golf oil filter screws straight onto a Mini, it's the same diameter but longer.. 8)
excerpt from Todd Miller's AustinAmerica US site-
"Because of my experience with German cars, I have always used German filters. The filters made by Bosch, Mann and Mahle are of excellent quality. The ones that I use fit the VW gasoline engined Rabbit/Golf/Jetta/Scirocco/Fox/Quantum/Pickup, etc. from '75 on. The Bosch part number is 72150. This filter is about twice as long as the stock sized filter and just barely fits due to the location of the reverse light switch on the manual transmission cars. But, with a little finese it goes right on. When using these larger filters, remember to check your dipstick after the initial start-up because the filter holds more oil (about 1/2qt.)."
 Post subject: Re: Larger Oil Filter
PostPosted: Wed Sep 21, 2005 7:00 am
I pay $5 for an oil filter, how much cheaper do you want them for?
Aaron
PostPosted: Wed Sep 21, 2005 8:02 am
Aaron
I was paying in excess of $15 for a filter. But i also like that fact that I can filter more oil and that I can use a complete 5L of oil now instead of 4.5 or so.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Wed Sep 21, 2005 9:20 am
Slow-Po
Doc, what brand / type of filter are you using?
PostPosted: Wed Sep 21, 2005 7:51 pm
At the moment, I'm running Delphi or Coopers (Mini) ones from Karcraft- but when my stock runs out I'll go to Pep's or wherever and suss out these VW ones. They have approx twice the filter area of a Mini one I've heard. :wink:
No idea of cost.... yet.
PostPosted: Mon Sep 26, 2005 2:58 pm
Sorry it took so long to click onto this one,,,but i`ve been using the ford escort "Z62" type for years & years
fits straight up, no mods
easy-peasy :-)
PostPosted: Tue Oct 04, 2005 8:22 pm
I checked out the Golf ones (Valvoline V051) at SuperCrap yesterday but at $20 each, they can keep them..... :x
PostPosted: Wed Oct 05, 2005 1:41 pm
Thats why I did the mod
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Thu Oct 06, 2005 9:33 pm
the ryco z62 filters, are essentially the same as the now out of production z82 just longer, in most cases they fit perfectly, although for whatever reason i have seen one which did touch the subframe.
If in doubt ask
