It is currently Wed Jul 02, 2025 11:14 am
PostPosted: Sun Oct 02, 2005 9:42 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i have a ingram twin relay i have seen the setup for the other type of relays but this one has
s2 b s1
l2 s l1 on the top
ok so i take it the the b is the power ???
s2 s1 inputs ???
l2 l1 outputs ?????
s ???
help
makka
PostPosted: Mon Oct 03, 2005 12:09 am
At a guess
s2 s1 inputs ??? = Signal2 Signal 1 inputs ( High beam/low beam from switch)
l2 l1 outputs ????? = Lamp2 Lamp1 outputs ( High beam/low beam to lights)
s ??? = not sure, maybe earth.
PostPosted: Mon Oct 03, 2005 12:11 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
wow i'm good at this guessing game lol
thanks drekkus will have h4's in the car in the arvo
and then be able to see at night
makka
PostPosted: Mon Oct 03, 2005 9:36 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ok all done and i can now see were i am going yay
also replaced the fuse box and rewired it with new terminals all crimped and soldered now when i put my blinker on the sterio stays on the charge lite dont come on anymore cos i cleand all the terminals also netend up some of the wireing cable ties and stuff next is to put my uhf radio in then after that is to finish the 1275 and put it in and i think i beeter get my rear into gear as the motor is starting to lose oil pressure so how was you public holiday :)
makka
