It is currently Wed Jul 02, 2025 2:33 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sun Oct 02, 2005 8:33 am
I'd run a filter on that :shock: Won't last long running it without one...
Lillee - 1969 Morris Mini K
 Post subject: Full rebuild
PostPosted: Sun Oct 02, 2005 10:39 am
Go the full rebuild and include an antivibration spacer. Stops fuel froth and the knock on effects.
seeing you've got a "air box" you could go a longer manifold and junk that swan neck one
The 4 numbers are there for matching purposes and you'll find on factory cars with the twin setup they run sequentially. For minis it doesnt matter
A fundemental thing to understand is that carb is really 2 carbs in one body. They share a common fuel bowl and a very similar so your settings on the tuning side should be very similar or something is wrong.
Finally put a cover plate between you and the carb. It wont effect carb performance but might save your life (unless your after a darwin award)
PostPosted: Mon Oct 03, 2005 7:15 am
I wouldn't call that manifold of yours a `swan neck' (THAT acronym is reserved for the tall Lynx one and others you can't see thru....) :lol:
If you want to improve it heaps, just port it out. At least you have room in there now for a nice K&N filter..
Open it out to add volume and increase its cross section, mainly in the bottom half.
I can recommend Des Hammill's book `How to power tune the BMC/BL/Rover 1275 A series engine'. Has pics. $39.95 at www.pitstop.net.au
I use a Redline 3005 one, which when stock used to flow 137CFM. After a fair bit of work with the die grinder it flowed 188. It is probably ~200 now that I've attacked it more since, using GR's suggestions.
By comparison, the best new one about now (GR's) flows 240CFM... which is probably only of extra benefit on a race car, which mine is not. 8)
