It is currently Wed Jul 02, 2025 7:19 am
 Post subject: Me 1 : Trumpet 0
PostPosted: Sun Oct 02, 2005 8:14 pm
A $15 (6 months warranty i might add) angle grinder from bunnings and 2 hours later the score was me 1 : trumpet 0
PostPosted: Sun Oct 02, 2005 8:26 pm
2hours! took me 2min to cut through my trumpet with a jigsaw :lol:
PostPosted: Sun Oct 02, 2005 8:44 pm
mine is in more peices cause i couldnt lever it out from the cone, it was serized. the other side came out much easier tho
PostPosted: Sun Oct 02, 2005 9:14 pm
Bastard of a things, i assume your putting in hi-lo's then?
Did you get the cone out without removing the top arm?
PostPosted: Sun Oct 02, 2005 9:33 pm
Yeah i put Hi Los in but reused the old cones, i wasnt able to get them out with the top arm still in. and besides i cant afford new cones atm, ive spent way too much money on this car lately. its got a main line into my wallet
PostPosted: Sun Oct 02, 2005 11:15 pm
Can I ask why you have to cut the trumpets up like this?
As I have seen this done many times and I dont know why?
So was just wondering do they get stuck or something so you cant get them out?
Also do they have to be cut even if you use the rubber cone suspension compressor tool?
Thanks..
Opinions expressed by me are of my opinion only and are copyrighted to Kinkabell Corporation? 2006.
PostPosted: Sun Oct 02, 2005 11:18 pm
yup, I reckon it took me 15mins a side using a hacksaw blade with my hands.. only needed one cut in the right place ;) the two bits look exactly like Mini Mads bits. Luckily my cones came out without too much trouble
www.crazybitchracing.com
PostPosted: Sun Oct 02, 2005 11:43 pm
is it possible to get the rubber cones out without taking the top arm out? i couldnt get mine out.
Is there a Tecnique? or is it just not possible
PostPosted: Mon Oct 03, 2005 1:12 am
General consensus is your replacing them with Hi-lo's and it's just so much easier to can't the damn thing than stuff around.
I used a cone compressor on mine and usually what you get is the top part of the trumpet stuck to the cone and it aint' ever coming apart unless you cut it. Even out of the car I couldn't seperate the top of the trumpet from the cone on the other side.
Is it possible to get the cone out without taking the top arm out?..
Well aparently..yes..it has been done..took brad 2 or 3 hours of bashing and getting lucky just to get one side out..technique? VVBFG and a VFLSD (Screw Driver or similar) from top...bash the sucker out..
Me..I prefer to remove the arm, give it a clean and once over, check the bearings etc..
This is what it looked like once back in and all cleaned up:
PostPosted: Mon Oct 03, 2005 7:22 am
Geez Josh that top bumpstop is well past it!! Due for a change... :wink:
PostPosted: Mon Oct 03, 2005 8:11 am
The other side is new...top arm doesn't come anywhere near it now anyway :lol:
PostPosted: Mon Oct 03, 2005 1:40 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
is it worth it going for the hi los?
how much does the lot cost?
blake :wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Mon Oct 03, 2005 2:23 pm
Yes it's worth it. Only other way to adjust height is shorten trumpet/add washers. Messy.
Full set will cost you ~$250 probably. Cheaper on eBay.
PostPosted: Mon Oct 03, 2005 2:32 pm
Yeah its definatly worth it. you can get hi los for around $50 to $60 each, depends on where you go, if your gonna put them in the back u'll need extension bars, i think they are about $20 to $25 each. putting them is a peice of cake. the hard part is getting the old trumpet out. as seen above it takes a bit of persuasion
PostPosted: Mon Oct 03, 2005 7:02 pm
my trumpets basically fell into my hands this afternoon....i dont get it....havent tried the fronts yet though.
I have a problem.. apparently
Users browsing this forum: No registered users and 23 guests
