It is currently Tue Jul 01, 2025 7:47 am
PostPosted: Mon Sep 26, 2005 5:10 pm
I'm looking at building a screwcharger set-up for my 998cc. I was thinking of going with a 1275, but I don't have one, don't feel like looking for one, and don't want to ship one. I have a stock 998 right now, so I'm just going to build that up, but I want to copy Mucho Money Mini Mania's screwcharger system and use it on my 998cc.
Any reason why I shouldn't do such a thing? Also, I'm thinking I'm going to have to run lower compression. Would a 12G295 head help lower it a bit? The current head is a 12G4816 or something like that.
I know there's more that has to go into this, and I have read the thread below as well.
Ideas/Opinions/comments?
Thanks
PostPosted: Tue Sep 27, 2005 12:36 am
Gday Beau - its a good idea as I am still contemplating the idea too. Some words of advice though before you do it...
1. What cylinder head are you using? I have a nearly finished 998cc rebuild and have the 12G202 heavily ported head off a 1098cc mini. The engineer took the peaks(beaks, the pointy things in the combustion chamber)off and relieved the valves a little. Stops hot spots in the head when you blow it(turbo too...).
2, Plan to plumb in the oil feeds to the blower from the engine - do not rely on the piss-ant reservoir they provide you with the aussie kits.
3. Get your CR right. I stuffed it for a blower(9.5:1 vice the 8.5:1 I wanted - Ce La Vie!!). Get the head buretted, pistons done too if dished, check your deck height too(my pistons are a poofteenth proud of the engine face).
4. Just do it!! I drove in(passenger actually!!) a 998cc blown(sprintex) mini and freaked me out. Retain the 10" wheels and watch your tyres disappear. Braking upgrade is essential(as is a sissy bar for the passengers side dash...lol). Trust me - I had finger marks in this fellows dash - scary ride...
Hooroo mate and good luck -keep us informed...
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Wed Sep 28, 2005 7:24 pm
Stay tuned!
I have the ultimate budget supercharger build coming up!!!! :twisted:
Can't share anything yet......but stay tuned!
Can you say cheap?
PostPosted: Wed Sep 28, 2005 7:34 pm
:shock: :wink:
I have soe other plains for my little 998 but will very interested in what your doing :wink:
PostPosted: Wed Sep 28, 2005 7:36 pm
I know how to say CHEAP ..... see CHEAP CHEAP CHEAP
definately keep us updated :)
PostPosted: Wed Sep 28, 2005 7:38 pm
id say go the 12g295 head im pretty sure the combustion chambers are bigger and thus lowereing the compression. im pretty sure they are 27cc? aposed to 24cc? for a 12g202
also the 12g295 head is a good performance head as it flows better so yeh id say if u can find a coper head id go for it :wink:
PostPosted: Wed Sep 28, 2005 8:26 pm
Another possible head I have to use is a 12G1316. It's a 1275 head, and I have been told I may have to pocket the block a little. I was told that it may work without and pocketing though, as long as the head hasn't been skimmed to much.
Supercharger dimensions are 12" long, 7" wide and 5 inches deep. It will work on 1 liter engines too.
PostPosted: Wed Sep 28, 2005 9:45 pm
be sure to tell us more as soon as u can
PostPosted: Tue Oct 04, 2005 1:12 am
Sounds like an AMR300 / AMR500 supercharger..... just like my old one...
PostPosted: Tue Oct 04, 2005 9:26 am
i got a 998 too
the plans for it are to overbore 10 thou, new pistons, stroking with an 1100 crank and then rego.......after rego it'll get some disks tooo might even supercharge though i wannna do the 4efte after my account goes back up again
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Tue Oct 04, 2005 3:09 pm
That looks like a Fuji Industries (subaru) supercharger ive got one mounted on the front of my 998 clubman
PostPosted: Tue Oct 04, 2005 3:49 pm
I now have a 1275 to build, so the 998 is gone for now. I will be running a Eaton supercharger. More details soon. I'm not planning on making kits either, just want have a DIY sort of thread.
