It is currently Tue Jul 01, 2025 8:15 am
PostPosted: Tue Sep 27, 2005 1:26 am
http://www.hi-flow.com/HPAirFilters.htm
check these out, the quality is excelent, although i have only half a cm or so of clearance between the back cover and the side of the centre speedo hole with their base filter. so their tapered offset would be the best option.
Cheers Steve
 Post subject: weber
PostPosted: Tue Sep 27, 2005 6:10 am
Kevin, it's actually a DCD weber I'm replacing.....but without using a dyno it's easier/cheaper to get an SU tuned on an A series (around here anyway). The weber is 'roughly' OK but not quite for this engine.
minza - pity they don't list prices...
 Post subject: Re: weber
PostPosted: Tue Sep 27, 2005 6:50 am
Yeah I'm with you there. I had a Fiat with a stock 34DHS? downdraft Weber on it.
Can't do a lot to them... economy wasn't bad, though. :wink:
PostPosted: Tue Sep 27, 2005 11:44 am
i paid 80 for the pov pack filter with just a paper element.
i put this on at the same time i did the cam, head, dizzy and carb so i couldn't say if it does anything or not.
Cheers Steve
PostPosted: Tue Sep 27, 2005 4:19 pm
1380 yellow devil wrote:
By special order only otherwise only hi-flow
Sorry are you talking about the offset mini K & N Filter?? If you are, try Rocket Industries. They have them in stock - I bought one from them only a fortnight or so ago.
Bob Slattery
Users browsing this forum: No registered users and 23 guests
