It is currently Sat Jun 21, 2025 10:08 am
Post new topic Reply to topic  [ 377 posts ]  Go to page 1, 2, 3, 4, 5 ... 26  Next
PostPosted: Wed Aug 11, 2004 7:37 pm
OK boys and girls:
A Pulsar N12 electronic dizzy is already the right diameter and length to fit a Mini. No shaft cutting or body machining is needed.
For fitting one to an A+ motor, read this thread, then the other one in A/A+ Mods forum. viewtopic.php?t=11178
1. First get your Pulsar dizzy. Comes off an N12 Pulsar, 1600cc, late 80's.
Part Numbers: stamped on dizzy body near the vacuum canister-
Pulsar auto- D4R83- best on 848-998-1098 <edit> will work on stock 1275 but D4R85 is better.
Pulsar manual- D4R85- best on modified 1275 up, big cam, carb, head etc (IMO)
<edit> the auto has 16* dizzy mech advance & the manual has 12*
Double these numbers to get crank advance degrees.
2. Get an old Mini dizzy- any old thing will do. You just need its drive dog.
3. Remove pin from Pulsar drive dog with a 1/8" pin punch and BFH.
4. remove pin from Mini drive dog with a 3/16" pin punch and BFH.
5. Remove the Pulsar drive dog. Put Pulsar dizzy in a vice on a bench drill, clamp the shaft and carefully enlarge the pin hole with a 4.5mm drill, then a 3/16" drill. Keep it straight and square.. :wink:
6. Put the Pulsar thrust washer on the shaft, then slide the Mini drive dog on. The pin holes may not line up- if so you would then need to remove 1mm (.040") approx from the top (flat) face of the drive dog. Ideally you want .005"-.010" end float when it's assembled, with the thrust washer in.
NOTE: fit it so the rotor's brass strip is pointing at 1 o'clock, and the `drive key' is below centre of Mini drive dog.
7. Run the 3/16" drill thru the dog and shaft to ensure alignment. Fit the Mini pin.
8. Put the dizzy in a vice, holding it by the slotted Lug. Then get a hacksaw and cut the lug off.
9. The flange of the dizzy body is already the right diameter to fit into a Mini clamp plate. File or linish the part where you cut the lug off of, so it matches the rest of the flange. Use a clamp plate to check when it's right.
10. Use the Pulsar coil. It is 1.5 ohm, so if you wanted to you could use a Bosch GT40-R coil instead. But no need- mine fires .040" plug gaps to 8000 rpm...
NOTE- although it may be marked as a resistor coil NO RESISTOR IS USED with this dizzy.
Pulsar coil primary leads are long enough that you can put the coil on the inner guard if you want (keeps it dry) :wink:
<edit> fixed typos, added more detail..
Last edited by drmini in aust on Sat Sep 24, 2005 10:38 am, edited 7 times in total.
PostPosted: Wed Aug 11, 2004 7:44 pm
cheers doc...
PostPosted: Wed Aug 11, 2004 11:06 pm
awesome!
Kev, can I have your permission to post this on my own website?
 Post subject: DIZZY
PostPosted: Wed Aug 11, 2004 11:07 pm
Hey mate what is the advance on this dizzy. do you know?
PostPosted: Thu Aug 12, 2004 3:23 am
....my brother girlfriend drives one of these..... maybe i'll swap 'em over one night when theyre not looking :lol: :lol: :? :wink:
PostPosted: Thu Aug 12, 2004 7:13 am
J_A_M wrote:
awesome!
Sure, no problem. Royalties will be 1 case of Hahn Premium per month.. :lol:
Just kiddin'...
clubmn-
read my post above. Auto dizzy has 16*, manual has 12*, all over by 4000 rpm. Works nice on mine... :P
These figures are dizzy degrees- so that's 32 CRANK degrees and 24 respectively. 8)
PostPosted: Sun Aug 15, 2004 9:25 pm
I am doing some research for a write up on this subject, for my website. While searching the net for some pics of this distributor, I found the following sites:
http://www.mcs.vuw.ac.nz/~kris/escort/ignition.shtml
and
http://w1.481.telia.com/~u48109185/restoration14.htm
Neither are for a mini, but they outline a conversion to this type of dizzy. It seems it is a Hitachi made part.
PostPosted: Sun Aug 15, 2004 9:34 pm
Yep, they are a Hitachi dizzy.
Good articles. Keep up the good work, grasshopper... :wink:
PostPosted: Mon Aug 16, 2004 8:28 am
Posted an article on my website for this conversion. Basically it's Kev's write up (and a very good one Kev!) with some pics. No one from here will get anything more than what Kev has already written in this thread, but for the 150 odd visitors to my site every day that dont frequent this place, they will get a lot from it I am sure.
Thanks Kev! 8)
PostPosted: Mon Aug 16, 2004 8:48 pm
With that number of freqents we should keep the secret to our selves :shock:
PostPosted: Mon Aug 16, 2004 9:45 pm
lol...yea dont count on Pick and Payless having any for a lil while.... :lol:
PostPosted: Mon Aug 16, 2004 10:18 pm
Heh- when they're all gone from everywhere I'll sell my Lucas 45D & Pertronix for a fortune.. :P
Then again... :?
PostPosted: Mon Aug 16, 2004 11:23 pm
There are a few more places to go for Nissan parts, but it won't be as cheap as Pick n Payless... Anyway I am hoping so! :wink:
Lillee - 1969 Morris Mini K
PostPosted: Tue Aug 17, 2004 8:54 am
just rang a nissan wrecker.... $140 for the dizzy :shock: ..keep looking...
PostPosted: Tue Aug 17, 2004 8:58 am
:shock: anyone else got a price for one? I am now wondering what we will have to pay for one.
Users browsing this forum: craigb and 16 guests
