leyland74 wrote:
If by clubby you mean Leyland then yes it is, I remember some sort of printed circuit. so pull them out from the front?
I like music so I think a 40mm Dellorto or Weber sounds like the go, I don't like the idea of tuning twins either.
What do you mean by "1275 stage 2 head" what's stage 2?
How much is a 40mm Dellorto or Weber approximately with any manifolds?
"RE13 cam might be a bit hairy"
I don't mind hairy
but I guess that means need disks? or could I avoid that and run boosted drums (I've heard the term, is that running a bigger booster or duel boosters or something.) What should I budget for this (with me ripping heads and carby's off and giving them to machinist etc to port and put cams into). Is this a $1000-1500 job or a $2000-$3000 cause I'd like to go for more the first (shouldn't spend too much but want some fun/more grunt).
Thanks.
Paul.
Yes the bulb pull out towards the driver.
Stage 2- I mean slightly ported, to still use the stock 1275 valves, recut the valves & seats, back cut the inlet valves, fit a set of stock Cooper S valve springs, clean up the dags in the combustion chambers, polish but not too smooth, surface grind the head to clean up. You will have C/R of about 9.5:1 in a 1098.
You DON'T need oversized valves in this head for a 1098.
40mmDellorto S/H- how long is a piece of string? Probably $200+ unles you find a bargain.
Manifold to suit- $100-$200+ depending on how S/H it is..
`RE13 might be a bit hairy'- what I mean is, the power peak may arrive a bit high in a 1098 with this cam and head. And it may lose torque at low speed. Really you shouldn't rev a 1098 past 6500 for any length of time.. so cam it accordingly. A works 731 cam is not bad in a 1098. Kent 266 is OK, or ask Graham.
These heads do breathe better than a 202 head (or a 295!)
Drums are fine if in good condition. If you can't afford discs at least overhaul what you have- new wheel cylinders, machine the drums, new shoes to suit. A servo will NOT make it stop faster, it will only reduce pedal force.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
