It is currently Mon Jun 30, 2025 7:19 pm
PostPosted: Mon Sep 12, 2005 4:13 pm
Just wondering of any of you have converted a starter from another car to fit a Mini? Not sure if it has been done, but I thought I would try!
Thanks
PostPosted: Mon Sep 12, 2005 4:16 pm
Holden Gemini starter motor works I am not sure of the specifics of it but if you do a search there is mention of it somewhere on this site....
What is a Holden gemini called in the US? Gemini's had a link with isuzu I think :? so maybe that will help. :D
Roads need more corners
PostPosted: Mon Sep 12, 2005 4:22 pm
Slow-Po
The Geminis are called Chevette in the Americas.
PostPosted: Mon Sep 12, 2005 5:29 pm
A chevette? As in the Chevy hatchback?
Image[/url]
PostPosted: Mon Sep 12, 2005 5:49 pm
Slow-Po
The T car! :wink:
http://www.chevettes.com/
PostPosted: Mon Sep 12, 2005 6:19 pm
Yes the Isuzu starter will work but there is a better one that takes more work to get it to fit, the Honda Civic, it's a corker apparently. I have all the info but it's on my work computer.
PostPosted: Mon Sep 12, 2005 7:52 pm
Chevette in US had a different engine to the Gemini here. You can use a starter from a 2000cc petrol Trooper or 1600-1800 petrol I-Mark. Maybe an Impulse as well. :wink:
(Yes, I'm a closet Isuzu fan!)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Sep 13, 2005 10:18 am
:wink:
RWD Gemini fits. Needs the mounting holes elongated but interferes with your oil cooler if fitted. Give Link a call. They had them last time I was there.
Edit: :oops: OOPS didn't notice you were in Minnesota.
Regards
RonR
PostPosted: Tue Sep 13, 2005 10:24 am
miniron wrote:
:wink:
Regards
RonR
No worries. Chevettes are a tough car to find here. Couldn't find anything from any of the local yards.
I was wondering if there were any asian cars that would have soemthing. I don't want to use American car parts.
PostPosted: Tue Sep 13, 2005 10:04 pm
holden gemini is isuzzu bellet or vauxhall chevette i think
PostPosted: Tue Sep 13, 2005 10:09 pm
Yes, as was said above! :lol:
Chevette uses a different engine entirely.
The Bellet uses a different starter which does not interchange.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Sep 13, 2005 10:20 pm
point being the chevette is not a chevrolet product as beau suspected but a vauxhall..still GM though.. theres probably a german opel equivelent too...
PostPosted: Tue Sep 13, 2005 10:36 pm
Yes there is, the Opel Kadett of the same period.
But as far as I am aware, the closest thing the US got was the I-Mark which is basically a Gemini to us:
Not sure of exactly what the mechanicals were.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Wed Sep 14, 2005 2:26 pm
Slow-Po
Beau;
In case you missed this thread
http://www.ausmini.com/forums/viewtopic.php?t=11151
 Post subject: Gemini starter
PostPosted: Sat Sep 24, 2005 11:50 am
The gemini starter develops a lower cranking torque but achieves this with a 20% lower current draw.
Fitting a gemini starter will give the perception of better cranking but there is little diff. I personally did the mod then did the check.
