It is currently Mon Jun 23, 2025 10:01 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Thu Aug 05, 2004 7:08 pm
thanks doc
very helpful
Inconspicuously Conspicuous
PostPosted: Thu Aug 05, 2004 8:08 pm
Doc, hmmmm would there be similar level of stuffing around fitting the K1 head as there would be to fitting the K1 motor to a mini gearbox? Pardon my ignorance but what is involved in fitting another motor to the mini gearbox?
JC
PostPosted: Thu Aug 05, 2004 8:38 pm
My thoughts exactly. Mind you, then you have more BMW parts in there... :lol:
Not seen a K motor, might be made to fit, might not. I do know they run anti-clockwise though- nothing some new cams and ingenuity can't fix.. :lol:
 Post subject: Forget it!!
PostPosted: Thu Aug 05, 2004 8:42 pm
JC
:shock:
It has all been tried before ....but...why would you want to stick anything but an A Series block on top of that gearbox????
Fiddle to your hearts content with XFlo heads etc but man.....if you going radical then think about a Supercharger, Honda or Suzuki transplant is my advice... :?
PostPosted: Thu Aug 05, 2004 8:55 pm
Probably would be easier to fit the K motor to a jap box than a Mini one.
Not that I like hybrid Minis anyway.
Putting the K100 or K1100 head on an A series involves a lot of work- I believe 2 head studs do line up (sort-of) the rest don't. Then you need to totally build a cam drive system... oil drains, etc, etc... worth it? I dunno. I'll stay with A series... :lol:
PostPosted: Thu Aug 05, 2004 9:21 pm
Here is a site on now to fit the bmw k1 head to a mini.
http://www.miniman.com.au/bmw.htm
olly.
PostPosted: Thu Aug 05, 2004 10:04 pm
Those are old pics- Matt's now thrown away the chain drive to the cams- he's fitted a timing belt system. Posted a pic on MM site a little while back. :wink:
