It is currently Wed Jun 25, 2025 3:14 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Sep 02, 2005 10:31 pm
Thats the part I'm dreading, pulling the harness out. I pulled the dash out last night andexposed everything.
PostPosted: Sat Sep 03, 2005 10:31 am
Yeah Mime it can look pretty scary just make sure you tag things as much as possible it will make things easier. I was actually wondering how to get the loom on the cabin side out into the engine bay but it all goes through the hole in the firewall (after a bit of jiggery pokery).
PostPosted: Sat Sep 03, 2005 8:25 pm
The loom can look bit daunting but if you have a wiring diagram it all makes sense and is not to bad to sort out what you need and bin the rest.
4efte powered Clubman
supercharged 998 race car
PostPosted: Sat Sep 03, 2005 8:34 pm
92 it ends up my halfcut ran ABS to remove these wires (not necessary I know) do I just follow them back to where they originate and cut them off? Also I have the wiring diagram that everyone else has that I think was translated by Paul of Tatsumaki fame is that the one you used?
PostPosted: Sat Sep 03, 2005 9:04 pm
ABS that makes it a bit more difficult if it dosen't run to the engine ECU it should be fine to cut out. My loom i took out every thing that wasn't asociated with the engine and used a new fuse box and relay board to minimise all the wiring.The diagram I used came from toyotaGTturbo.com
PostPosted: Sun Sep 04, 2005 12:20 am
Yeah 92 I noticed that the loom seems to have two fuse boxes the big black one and one that goes inside the cabin. I'll have a go during the week and see how I go and maybe get back to people if I have any :?: :?:
 Post subject: Leave em...
PostPosted: Sun Sep 04, 2005 9:54 am
Matt, if they ain't bulking up the loom too much then just leave them with insulated terminations....never know when you are going to need a spare cable run.....5 centavos.
PostPosted: Mon Sep 05, 2005 12:09 am
Hmmmm can we do ABS?
Baracade
PostPosted: Mon Sep 05, 2005 8:27 am
Well Dean, having had a look possibly. But the hubs etc on the Starlet seem to be designed for the ABS is there is a fair amount to it. I think with vented discs with four pots it is a bit OTT also are you running a booster? It would be nice but alot of work. Why not ask Mr Enforcer I think he will agree but he could possibly give you better info as to the pros and cons...Its a pity I don't have the Toyota hubs with me I could take a photo and you could see what I mean...
PostPosted: Mon Sep 05, 2005 10:15 am
Yeah I am using the vented disks & 4-pots...
As for the brake Booster thats a must... I have to have one for it to be legal... aparently...
Hmmm I will ask Mr Enforcer about the Pros & Cons to the ABS... & let you know...
Baracade
PostPosted: Tue Sep 06, 2005 8:27 am
Yeah Bara ask Mr Ed it would be an interesting adaption. Imagine doing stoppies (like on a motorcycle) in a Mini. I should have my driveshafts today or tomorrow so things are moving along, only downside $500. But once again big fish, small pond...
PostPosted: Tue Sep 06, 2005 2:08 pm
yeh matt mine where about $500 too, but they took bloody 3 months to do them :shock: I sent the the starlet shafts and after 2 months of not hearing from them i found out they had stuffed 1 side up, and where looking for another shaft to complete them.
In the end they couldnt find any shafts so made me some billet shafts up :D same price and will handle 500hp 8)
1974 Moke - 998cc
PostPosted: Tue Sep 06, 2005 3:04 pm
13secmini wrote:
will handle 500hp ......
That sounds like a challenge......
PostPosted: Tue Sep 06, 2005 3:35 pm
Billets are what I am getting... they are $800 for the pair... Is it worth the extra 300???
Or are you getting the Billet ones for a even better price?
You are flying along Minster... at this rate you will be on the road in no time...
Quick question... are you better off using a new loom? As they are only $200...
Baracade
PostPosted: Tue Sep 06, 2005 7:13 pm
My shafts are billet only $400 for the pair I did do the lathe work myself though
